Results 1 to 5 of 5
    Mar 2011
    Giant Yukon FX headset specs
    Looked all over but couldn't find anything on the net. Even emails to Giant and Cane Creek resulted in nothing. So I figured I's post the specs for people in the future.
    Removed the old FSA headset, loose ball style (Traditional or Semi-Integrated (ZS))
    Upper Headtube Diameter: 43.94mm
    Upper Headtube Depth: 8.90mm
    Lower Headtube Diameter: 43.95
    Lower Headtube Depth: 8.95mm
    Hope this helps someone in the future.
    What did you end up replacing it with? My wife will most likely end up with my Yukon but id like to upgrade the headset when I upgrade the fork in the next few months.
    2010 Giant Yukon FX
    Pure XCR Wheelset/Geax Saguaro Tires/Tubeless
    Bike Weight Lost: 2.48lbs (1124g)
    Mar 2011
    Haven't yet, waiting on a response from cane creek Chris King or Hope. I just want to go to a sealed bearing as I ride in alot of wet/muddy/slushy conditions this time of year.
    Will post a list of a few once I've heard back.
    I had the same headset come stock with a frame. I replaced it with this:
    Universal Cycles -- Cane Creek 40 ZS44 ZeroStack Headset - Black
    Sorry to resurrect an old thread... does this mean I could use one of these to run a tapered fork?
    Hope Type H EC44/40 Lower Headset > Components > Headsets > Headset Lowers | Jenson USA
