Results 1 to 13 of 13
    Reputation: parkp81's Avatar
    Giant Trance Upper Pivot - Gap normal?
    2011 Giant Trance X
    I just noticed this, but I recently changed my bearings and triple checked everything, the bearings are completely seated in the housing on the upper triangle as well, but for some reason the spacing is different from left (0.22mm gap) to right(0.53mm gap). The right side has more of a gap then the left side. The spacers are the same width , which was the first thing that came to my mind maybe the spacers are different from left to right, but nope. Is your like this? I'm just wondering if the left side will ever end up rubbing, its so close together.
    Giant Trance Upper Pivot - Gap normal?-20130506_221054.jpgGiant Trance Upper Pivot - Gap normal?-20130506_221118.jpg
    Nov 2012
    Hi there,
    I have 2012 model which is the same frame as yours.
    Have no pictures to send to you yet, but yes they all have the same gaps.
    And I do not think they are loose in any way.
    Cheers and hava look at my post of my converted Trance 650b.
    You mean your right side has a bigger gap then the left side like mine?
    Nov 2012
    Both my gaps were wider than yours, I think one was wider than the other.
    It was checked properly for lateral play during the rebuild, it didn't take a lot of torque before the entire fitting tightened up perfectly, while still maintaining full movement of the ball bearings. So yes, you should be in safe hands.
    Got it, thanks.
    So I took the left side apart again and got my handy socket and c-clamp out and pressed it in a smidge more, still not even with the right side. I'll just ride and hopefully nothing happens. =)
    Nov 2012
    As the photos show, my right gap is also more than left.
    If it worries you too much, remove the bolts of the seattube & shock, and test for lateral play. Tighten (gently) till its zero play. And at same time not so tight that friction causes rub on bearings. It ain't a propeller bearing.....
    Attached Thumbnails Attached Thumbnails Giant Trance Upper Pivot - Gap normal?-dsc_0112.jpg
    Awesome, thanks for taking the time to take an actual photo. Mine is exactly the same as yours now.
    Nov 2012
    Most welcome ParkP, hope you ride with confidence now.
    You frame seems like a matted alumminium coat, as opposed to my gloss black.
    Does dirt/soil stick to it ? Do you find it easier to maintain to a gloss coated frame ?
    I'm generally a fan of matte coats, both the ori alluminium and black colours looks great on Giants.
    Yea, its I believe just clear coated over the bare aluminum. I like it. The dirt does not seem to stand out as much compared to a dark color coated frame, its really easy to maintain, also a big thing is it hides scratches very well. I've had a dark coated frame before and that thing you notice all the scratches.
    Reputation: mizzaboom's Avatar
    Jun 2010
    Just to chime in here...after reading this I looked at my pivots and have a similar gap. Bike is basically brand new too, half a dozen rides. Glad to know it is normal. Cheers.
    All good things in all good time
    Good to know. Thanks mizza.
    Jun 2010
    No prob, park!
  1. Replies: 6
    Last Post: 10-27-2015, 03:43 PM
  2. Replies: 1
    Last Post: 02-06-2013, 10:02 AM
  3. Trance X broken upper shock mount bolt
    By 661lee in forum Giant
    Last Post: 03-15-2012, 04:14 PM
  4. Upper and Lower EG Pivot
    By iammemares in forum Titus
    Last Post: 01-18-2012, 11:07 AM
  5. Looking for an upper pivot axle for a Blur 4x/1.0
    By amish_matt in forum Santa Cruz
    Last Post: 04-14-2011, 05:13 AM
