Results 1 to 10 of 10
    Reputation: jclyle's Avatar
    Jun 2012
    Giant SXC29-2 converting to tubeless
    I have a 2012 Anthem X2 with SXC29-2 wheels. I'm switching to tubeless soon.
    For those who run tubeless with stock wheels, did you have any issues with the conversion?
    I'll be using a Stans kit when I make the switch. Current tires are the stock RacingRalphs.
    I plan on upgrading wheels in a few months, its tempting to just get a set of Stans Crest or Arch to simplify setup.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    I have set those wheels up tubeless several times. It is pretty straightforward but not exactly easy. You won't get the satisfying pop you would with a Stans rim. The Racing Ralphs work great tubeless but the sidewalls will weep sealant for awhile.
    I'm a mountain bike guide in southwest Utah
    Jun 2012
    How much sealant do you add to the RaRa's? Any extra since you know they weep?
    DFMBA.org
    Reputation: MTBeing's Avatar
    Tape or a rim strip?
    Sent from my mountain bike while crashing
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    Your Best Friend
    I usually add just shy of two scoops, or two ounces per tire.
    Your Best Friend
    Tape is always the best way but I've used both.
    I've set up PXC29 using 1" gorilla tape, no problem.
    Jun 2012
    For those that used a Stans kit. Did you have to do any drilling in the rim for the valve to fit?
    Your Best Friend
    Quote Originally Posted by jclyle View Post
    Wait...What?! No.
    Click Click Click
    Reputation: dirtbyte's Avatar
    I think I know what you are talking about... One of the videos out there show a drill being used to make the inside hole larger. This is NOT needed. Put the drill away!
