Results 1 to 10 of 10
    Reputation: trek7100's Avatar
    Giant Revel 29er 0 or 1 or Giant Talon 29er 1?
    Between the Giant Revel 29er 0 or 1 or Talon 29er 1, do you recommend as an entry level bike? I plan to ride bike paths, 2 tracks/singletracks, nothing really aggressive. I'm kind of leaning towards the Revels, I'd like to keep my budget under $800. Thank you
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    This would be my suggestion:
    1) Talon 0
    2) Revel 0
    3) Talon 1
    The Revel 0 and Talon 1 are close in certain aspects of the part spectrum but IMO the Revel is a little better, don't even consider the Revel 1 if you afford any of the others.
    Apr 2013
    We have both the Revel 0 and the Talon 1. My wife rides the Revel and I ride the Talon. My advice would be to arrange to take both for a test ride and make the decision yourself? Personally, I liked the geometry of the Talon and it felt a little more aggressive and nimble than the Revel. Both are great bikes and you cannot go wrong, it's a personal preference. I also liked the Talon frame, so if I wanted to upgrade a few parts in the future, it would be something that I could grow into.
    The matte black on the Revel is bad a**
    Good luck!
    Mar 2013
    Quote Originally Posted by teebone110 View Post
    Good luck!
    What is different about the frames?
    I have not been able to find any data about this?
    Apr 2013
    Quote Originally Posted by speedneeder View Post
    If you check out the geometry section, you can see that the wheel base is slightly longer with the revel. Other then that, having them side by side you can observe slight differences between the frames. The talon has a more narrow cross bar as it approaches the seat post. It might also be lighter, not sure as i have not weighed them. My lbs said the talon had a better frame, but i dont have any additional data about this. Bottom line, both the revel and talon are sweet bikes!
    Mar 2013
    Thanks for the reply!
    I started mountain biking on a revel 0 in January and I'm loving it. I'm trying to decide if I want to upgrade a few things in the revel or trade up to a different bike. I can't find any weight info on the talk or revel frames.
    On the geometry, wheelbase, is this the same size frame being compared?
    Apr 2013
    yes, check out the Giant website and look at the geometry section and compare same frame size of the two bikes.
    Mar 2013
    Thanks teebone110. I was thinking they were the same frames.
    The main difference in geo are the wheel base, chain stay length and top tube length, the Talon is slightly shorter on the back but longer up front.
    Revel vs Talon (using the Small as reference)
    Top Tube - 22.4 vs 22.5
    Chain Stay - 17.8 vs 17.6
    Wheel Base - 42.0 vs 41.9
    Mar 2013
    Thanks dirt devil!
  1. 2013 Giant Revel 0 or Talon 1
    By 2xmks in forum 29er Bikes
    Last Post: 06-18-2013, 04:14 AM
  2. Replies: 53
    Last Post: 01-20-2013, 09:57 AM
  3. Replies: 12
    Last Post: 11-26-2011, 03:12 PM
  4. Giant Talon 29er 1
    By PoorCyclist in forum 29er Bikes
    Last Post: 09-10-2011, 08:14 AM
  5. Giant Talon 2 29er as first mtb?
    By Dewaholic in forum 29er Bikes
    Last Post: 08-28-2011, 09:03 AM
