Results 1 to 25 of 25
    Giant Reign sizing question.
    I am in the market for a giant reign and i was wondering about the sizing. I am 5.10 about 200 pounds, inseam 31-32ish. I was wondering between the medium and the large which would be a better size choice for me.
    Any input would be appreciated.
    Dec 2011
    Medium should be ok for you, what kind of riding do you intend to do? Can't you go test it at your LBS.
    I ride a medium reign x, I'm 6'1 and about 190lbs, inseam about 33ish.
    The bike is probably a bit on the small side for me but since I intend to do more downhill/technical stuff it is fine. The only downside to a smaller frame for me is its a bit harder on long rides/climbs.
    At 5"10" 170# - medium works fine. Large will be a bit heavier and slower on tight turns, but a longer wheel base if your doing steep.
    its an online deal. so no go on the test ride.
    5' 10" 195# went w large (i also have pretty long arms). Med felt really small to me and LBS insisted that if i plan to pedal a lot i needed the LG. Giant rep agreed with them. I have no complaints .
    Any input on the Reign X sizing for a guy that is 1/4 inch short of 6 feet?
    May contain nuts
    Reputation: Haggis's Avatar
    Depends a bit on intended use, but I'd say large, unless you have a bmx background...
    BMX background = yes. I am intending on using the Reign X for All-Mountain riding. I am currently riding a medium Bottlerocket with a Totem that I will switching over to the RX. I do feel that the BR is a little on the small side for some of the riding I do, but a blast as I can just hop over anything in the way..... (I rode BMX for 5 years before going 26) I can't seem to ride the BR for more than 2 hours as it just becomes too uncomfortable and too much of a chore... Thanks for the input.
    Reputation: golfduke's Avatar
    Quote Originally Posted by 440fish View Post
    same exact here. I felt the med reign was too small, and I'm exactly the same size as you- 5'10" and 195 (okay, 200), but with 'I need to custom order dress shirts' long arms. I am definitely happy I went with the L.
    5'10" 160 lbs and my medium feels perfect
    At 6' 155 lbs i ride a large. Perfect. Opted for a shorter stem, feels real comfortable. Medium would be too small
    Hello. Please gime me an advice... I am buying a 2012 reign 2. I am around 6.3 (191 cm), 180lbs (82 kg) and can not decide xl or l. I want to ride allmountain, some dh and some xc tours. Tryed both on dh and the l feels of course more comfortable on jumps...but haven't been on a longer tour. Would appreciate some advice...
    Try and find a store and at least have a hop over a medium, even though you intend to buy online. Getting the wrong frame size sux.
    I'm 6-3" and the large is perfect. Allmountain,xc, Freeride.
    I run mine with a 50mm stem and wide bars. It's perfect.
    Quote Originally Posted by Largextracheese View Post
    Do you have an reign x? Because they are a little bigger and don't come in XL... So you think XL is to big?
    Thanks for the replies...
    Large is great for a tall person. Mine is a reg. Reign.
    Love this bike.
    At my favorite pit stop.
    Nice pics! Did you cut the seat? It looks so low... Can you pull it out enough on xc tours or is it a problem with your height?
    Thanks.
    The seat is not pushed all the way down in that pic. In fact, that is the one gripe I have with the bike. Being tall, I have to extend the post pretty high for pedalling but then it doesn't go down enough for the steeps around here because of the bent seat tube. Right now the post is not deep enough into the frame when climbing really. The fix is a dropper post. Which I want ayways.
    Reputation: Reign2Rider's Avatar
    5'10" 175 lbs, 2008 Reign 2, medium is perfect, wouldn't want it any bigger...
    Who is than the XL for? I can not find anyone who rides reign in XL... Only for giants???
    I did ride on a specialized enduro small and a reign x medium recently. They are pretty much the same size to me and fit well (50mm stem) My tape shows they have the same reach at 40cm
    I am 5ft8 w/ 33 inseam
    Sep 2012
    Just picked up a Reign X2 new in medium, I'm about 5'11 and similar leg length and wieght. Medium suites me just right though had to shorten the seat post as it seriously long, ie max drop was at my optimum pedalling hieght.
    If I was an XCing I'd like a longer stem/top tube but i'm not.
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    You're at almost the border line between the M and L, if you want a flickable bike go with the M.
    No Stranger to danger....
    Reputation: Tone's's Avatar
    id go large, im 5'7 and i ride a medium and the small felt way to small, reigns are sized very small, they have a small cockpit, be very care full about what size you get, i think the large will be sweet for you, cheers
    Dont ever let the truth get in the way of a funny story....
    I bought a large (6.3 ft) and its perfect!! Thanks for the help...
