Page 1 of 14 1234511 ... LastLast
Results 1 to 25 of 328
    Giant Reign Modifications (Not Reign X)
    Hello,
    The purpose of this thread is to hear of modifications people have made to their giant reign to find out what works and what doesn't.
    I am very interested to know about switching the rear shock for something other than the DHX air. I have also heard of guys changing the stroke legnth on the rear shock to gain more travel ie...from 2" stroke and 6" travel to 2.35" stroke 6.75" travel. Anyone tried this?
    Here's my mods;
    2009 Giant Reign 0
    -36 Fox Talas , brings my head tube angle to 66.5 and the BB just over 14". I really like this setup, makes the reign much more capable on gnarly descents but just as versatile for climbs, XC type stuff. It comes with a 1lb weight penalty.
    -KS i950r adjustable seat post with 5" travel. For me this was necessary because as you know the interrupted seat tube on a reign did not allow for maximum extension for climbing AND total drop down for downhill. this post is awesome, adjust on the fly and have the seat right where you want it depending on what your riding. it comes with a 1/2lb weight penalty.
    -RaceFace Bashgaurd
    -Chromag 50mm Ranger Stem for better control downhill and less of a felling like i'm going over the bars
    -Chromag Fubars OS 730mm for extra stability, less twitchyness
    Post your Mods!!!!!!!!
    Attached Thumbnails Attached Thumbnails Giant Reign Modifications (Not Reign X)-img_0198.jpg
    kneecap
    I just installed a RP23 7/785X2.25 on my older 05 frameset. It works so well, that I'm going to swap out the DHX4 on my 08 frame & give it a try.
    The seatstay bridge comes very close to the seatube under full compression with no air in the shock, so I installed a hard rubber bumper on the seatube, but I think the ramp up in the shock won't allow contact anyhow, & after a handful of rides, no problems.
    The RP doesn't seem to blow through midstroke like my DXH, & I'm getting 6" +, feels great.
    I can 35 lbs less air in the RP compared to the DHX, & get a much better feel overall.
    24v
    24v is offline
    Scratch That Itch
    Here is my bike, and all of its current mods.
    09 Reign 1
    -Hayes Stroker Ace brakes 203/180 (I like these much better than the stock elixirs)
    -Hope hubs with Spank Rims and DT spokes (heavier than stock WTB wheels, but also stiffer)
    -Maxxis Minion DHF 2.5 dual ply tires(similiar traction to the stock Nevegals, more durable sidewall)
    -Shimano SLX crankset (I like the gearing better(36/22), and have no need for a big ring)
    -Ethirteen DRS Bash/Chain Guide (works great to keep the chain on when going over rocky terrain)
    -Kona Wah Wah pedals (bike came with clipless, not my thing)
    -Crank Bros Joplin seatpost (a must have for any bike imho)
    -WTB Rocket V seat (much better on my ass than that horrible Fizik seat)
    -Thomson 70mm 0 rise stem (stock 90mm was too long, the 70 is much better for downhill riding, and only slightly worse for climbing)
    -RaceFace Atlas FR Bars(I cut them down to 710mm. The extra width, and lower rise fits me better than the stock mid rise RaceFace)
    May 2010
    MODEL - Reign 2 (2009)
    SIZES - L (20")
    FRAME - AluxX SL aluminium, Fluid Formed, Maestro suspension system, 6.0''/152mm travel
    FORK - RS Revelation Race Dual Air 150mm Maxle Lite
    HEADSET - FSA
    SHOCK - Fox Float RP2
    HANDLEBAR - RaceFace Ride XC riser
    STEM - RaceFace Ride XC
    SEAT POST - Giant Alloy 30.9mm
    SEATPOST CLAMP - Giant
    SADDLE - WTB Devo SLT (215g)
    PEDALS - Shimano M520
    SHIFTERS - SRAM X.7 27 speed triggers
    FRONT MECH - Shimano SLX
    REAR MECH - SRAM X.7
    BRAKES - Shimano SLX
    ROTORS - Avid G2 185mm
    BRAKE LEVER - Shimano SLX
    CASSETTE - SRAM PG950 11-34
    CHAIN - Shimano HG53
    CRANKS - RaceFace Ride XC X-Type 44/32/22
    BOTTOM BRACKET - RaceFace X-Type
    RIMS - WTB Laser Disc Trail 26"
    HUBS - Atomlab 920F 20mm front / Novatech rear
    SPOKES - Stainless steel
    TYRES - Schwalbe Racing Ralph 26 x 2.25
    WEIGHT - 13.12kg without pedals and sigma/13.50kg with pedals and sigma
    I need a bit of advice, I have a reign (2008 i think) and WAS running Suntour Rux 130mm forks, I just picked up a pair of RS RECON 351's off ebay, they were advertised as 140mm travel, I looked in to this and it seemed ok. They arrived today and they length of them is the same as my Suntour and the air/weight setup chart on the fork gived settings for 80-130mm travel. I did think maybe keeping them because they are a lot lighter but holding them next to the bike it looks like I would lose about an inch in height and therefore a tighter head angle too.
    any advice please?
    Dec 2004
    I'm running a DHX5.0 7.875 X 2.25" stroke coil shock on my '08 Reign. Really happy with it. I weigh 150lbs and am running a 350lb Ti spring. '07 Marz Z1 RC2 (150mm) up front. I'm a fan of coily plushness!
    kneecap
    Quote Originally Posted by ir803
    any advice please?
    Since you asked.....
    Any bike with 6" of travel in the rear deserves at least the same in the front.
    Just my opinion
    I hear ya,
    Getting a little frustrated now though. the Recon's are going back. and I'm looking on ebay and the net for 140mm + lightweight air forks but I have a low budget, so i'm struggling, in the meantime the suntour's I have seems to leak air if I hit anything hard so not really rideable.
    I'm looking at RS's Marzocchi's and Fox's,I really want to try to keep the weight under the 2000g mark it ain't looking to good at teh moment.
    I keep seeing the Marzocchi RLO forks pretty cheap brand new but I'm hesitant at comments on jamming and the fact that Marzocchi don't recoment you launch off anything larger than a fart with them.
    I built up an 08 frame with an 08 Marzocchi 55 ATA which worked very well until it developed issues. Marzocchi just sent me a warranty replacement 2010 55 Micro- ti which after one ride also works very well. I think the best thing you can do for the Reign is run a 160 mm fork.
    "Pain Doesn't Hurt."
    Thanks, I just won a Marzocchi all mountain 2 150mm on ebay for £101, so pleased with the price let's see how the fork holds up. it's a touch heavier than I hoped for BUT...you gotta face up to the fact that even used, if you want long travel but lightweight you've still gotta pay, all the 44's 55's and fox 32's i saw on ebay went for at least £260, which I know is cheap relative to their new price but I just can't justify spending that much.
    Quote Originally Posted by kneecap
    See this thread: 05 Giant Reign rear shock alternative?
    Same frameset?
    free
    I really love this Reign from the Internet, minus the big rotors
    Anyone here with a medium Reign runnin a 2010 Lyrik and a dhx 5 or 4? Would really love to see this set up...
    Reign 0
    Hey.
    So I'm in the process of changing out the fork my XL Reign 0. Looking at either a Lyrik or a 180mm Totem. Anyone know of pros/cons to either of these forks? Both are 2010 2-step air models. Thanks
    Hey.
    yo kneecap, have you tryed this procedure out on your 08 reign yet? the dhx air hasn't been all that kind to me lately.
    Quote Originally Posted by gorgechefzeke
    Hey.
    i havent seen anyone put a 180mm fork on a reign yet, im curious to see how that'll turn out. i do know guys are loving the totems but those 40mm stanchions might be a bit much for the reign. how about a fox 36 talas or float 180?
    kneecap
    Quote Originally Posted by murrdogg11
    Haven't tried the RP on my 08 reign yet, been meaning to. It's been kinda fun to ride the older bike again.
    Looks like there's even more clearance on the 08 at the seat stay/seat tube junction.
    I'll do it & repost....
    Reputation: chris68's Avatar
    Anyone try out the 170mm Lyrik on their Reign? I was thinking about getting that but them new 2011 Fox 180mm look sweet!
    Here is mine. Nothing to crazy just swapped some parts around over the years. I'm about to put a old 55 on it to make it a little more aggressive. I have a few bikes but I must say that I love this rig!!
    Attached Thumbnails Attached Thumbnails Giant Reign Modifications (Not Reign X)-bike-pic.jpg
    Slick Rick
    Reputation: stefanb's Avatar
    Anyone know the ideal size for a coil shock on the rear?
    What i2i etc am I looking for?
    www.trailburn.ca
    2012 Norco Truax 2
    24v
    24v is offline
    Scratch That Itch
    Quote Originally Posted by stefanb
    Stock on the 08 and 09 Reign is 7.875x2.0. The Reign X is 7.875x2.25. I have read that you can use a 7.875x2.25 on the Reign as well without issues. That is the route I will go eventually when I switch to coil.
    Jun 2010
    09 Reign 1
    Here is my set up.
    Stock 09 Reign 1 size L
    Mods so far:
    Sunline V one 745mm (cut to 730mm) bars
    Atomlab Pimp Sealed pedals
    Chromag Trailmaster DT saddle
    Ergon GA-1 grips
    Recently dropped the big ring and running an E13 DRS Bash/chain guide
    Had to cut down stock seatpost 3" to get the seat to drop more
    Only a few mods.
    2010 Reign 0 (s)
    - Ritchey Carbon WCS (from old bike)
    - Fizik Grips (Heavier but i like the feel)
    - KS i950R (great investment)
    - Fizik Gobi Seat (from old bike)
    - Mavic Cross Max ST Wheel set (traded in when i got the bike)
    - Schwalbe Rear 2.25 Racing Ralph (Rides better than the thicker original at the back)
    Attached Thumbnails Attached Thumbnails Giant Reign Modifications (Not Reign X)-img_0655.jpg
    09' Giant Reign 1
    I've made a few changes from stock setup.
    -Fox 36 Talas RC2 (2010') (this is the most important upgrade, which really widens the bike's potential)
    -Fox DHX AIR 4.0 (2.25 stroke, and a small volume air can)
    -Truvativ AKA stem 60mm (stock was too short)
    -Mavic Crossline wheelset (more of a AM wheelset, and I needed something with a 20mm thru-axle)
    -200mm rotors (f+r), which came with the wheelset, and I weigh nearly 95 kgs with gear, so the standard rotors weren't giving enough stopping power.
    -Maxxis ardent 2.4 f+r
    Benefits from upgrades:
    -Slacker head-angle/more travel makes the bike a lot more capable on the descents. The travel adjust is a necessity, however, as I use it all the time for climbing and general riding. If you're going to get 160mm forks, get a travel adjust one for sure. It also makes it more stable at speed, with the longer wheelbase. The stock forks are ok for general trail use, but if you want to hit downhill specific runs, you'll want a bigger fork
    -The new shock rarley bottoms (more progressive from the small air can), which was a real problem on the stock Rp2 XV shock. It seems to use the travel better, with more mid-stroke support, and feels significantly smoother. The new shock also gave the Reign 170 mm travel, which once again, gives a smoother ride on downhill specific runs (I do lifted runs with it as well as general AM riding).
    -Wheels are stronger/laterally stiff, but are about 300 grams heavier. The tyres are a lot heavier, but are good for the downs (bad for climbing though, but I mainly climb for fitness so it's OK, kind-of).
    This bike was pretty awesome to begin with, but, the upgrades I've made have really turned this bike into a real 'all-mountain' bike, which can still climb, but absolutely rips on the descents. It's not as smooth as a dedicated down-hill bike, but, it's about 80% there, compared to around 50%.
    Attached Thumbnails Attached Thumbnails Giant Reign Modifications (Not Reign X)-front.jpg
    kneecap
    Jose, where did you get the new shock? Any reason why you bought a 4 instead of a 5 DHX?
    &, can I ask how much you paid for it?
Hot Deals
Contests
Latest Mountain Bike Articles
