Page 5 of 8 FirstFirst 12345678 LastLast
Results 401 to 500 of 729
  1. #401
    May 2013
    Quote Originally Posted by bikeboardorblade View Post
    Quite a wordy response to say get the float!
    Thanks for your opinion, is there a specific, less aggressive fork that you would recommend?
  2. #402
    Quote Originally Posted by ultimatetodd View Post
    It's tough to not fall into the trap of believing that you need a different bike for each different stretch of trail you ride, always wondering whether some specific component or the bike itself is overkill or underkill for what you happen to ride.......
    It's your bike and you can change what you want with it, just know that you can reduce the travel on your VAN 36, it's the same exact procedure as most any air sprung for like the float 36 the previous poster recommended, EXCEPT it's only slightly more work to cut the spring...I run my van at 155mm and find it's very well suited to all kinds of terrain...
    The whole coil spring vs. air spring debate comes down to a matter of opinion, (myself I prefer the tradeoff of an extra pound of coil spring weight for the gain in traction/plushness/reliability. With the superior damping of today's shocks the coil isn't just for DH anymore, and the same is true for air, not just for XC anymore...
  3. #403
    Jun 2010
    If you really want a Fox 36 (of some variety), onespeedpaul may be on the right track... Instead of spending money on a new fork, modify the one you've got. Although I would be hesitant to cut the spring as it will increase the spring rate. Couldn't you drop in a new 160mm spring?
    Other options to consider (in order of burliness):
    - Pike
    - Fox 34
    - Revelation
    -jm
    Sent from my Nexus 7 using Tapatalk 4
  4. #404
    Reputation: bikeboardorblade's Avatar
    +1 for onespeedpaul. Reducing the travel on what you already have is a good idea. If you do want to replace the fork I'd say the Lyrik Solo Air with the RC2DH damper. Lighter lots of adjustments, plush, tough as nails and doesn't require service every 30 hours to still feel great.
    You may find after riding what you have now that you're more than happy with it, and are willing to put up with "too much fork." My buddy has that fork and absolutely loves it.
  5. #405
    May 2013
    Thanks for the advice so far guys.
    I suppose I should have added that I don't do a ton of aggressive riding at the moment, and all downhill sections I ride, I have to first climb up so that's where my thought to "too much fork" came from.
    I thought maybe the (uphill) disadvantages of the fork might be outweighing the (downhill) advantages.
    If I reduced the travel on my VAN would it be better to cut my existing spring, find an spring in the size I want, or get a used spring and cut it?
    Are there companies that do this type of conversion?
    Would a new, or cut 160mm or 150mm spring give me a noticeable increase in climbing?
    Thanks again!
  6. #406
    Jun 2010
    Re: Giant Reign Modifications (Not Reign X)
    This discussion is a good one, and probably deserving of it's own thread... Regardless, consider where you ride, what you ride, and your riding experience. Are you fairly new to riding, or have you been riding for years and have a good grasp of your abilities? Average mileage/elevation when you ride? Hucking jumps? Visits to a bike park?
    Based on what you've told us so far, sounds like you pedal everything you ride... In which case, I would generally agree that your fork isn't ideal.
    Cutting your spring will increase spring rate. In other words, it will make the spring more firm. If you feel your spring is too soft currently, I would say go for it. Worst case scenario is you buy a new spring.
    However, if it were me, I would buy a 160mm spring if you were planning on keeping the 36.
    Your local bike shop could do the spring swap... Not sure what they would tell you about cutting the spring - they would probably tell you the same thing I did.
    It would likely put you in a more comfortable climbing position which may or may not result in "better" climbing. That Fox 36 180mm weighs about 6 lbs. That is a LOT for a bike that spends quite a bit of time climbing. In contrast, the Revelation is less than 4 lbs. Taking 2 lbs off your bike is substantial. But many people would gasp at the sight of a 6" bike on a fork with 32mm stantions like the Rev has. However, if you do a lot of pedalling, and not a lot of hucking, its a great option.
    Let me break it down this way:
    - If your budget is $0, then cut your spring
    - If your budget is extremely limited, buy a new 160mm spring
    - If you want to drop a bunch of weight from your bike, do lots of climbing, and have a few hundred bucks, buy a Revelation
    - If you want to drop a bunch of weight from your bike, do lots of climbing and hard descending, and have a $1000, buy a Pike
    - If you want to drop a good bit of weight from your bike, and really like fox, and have money to burn, buy a fox 34.
    If budget weren't a concern, conventional wisdom dictates the Pike is the best choice at the moment. Super light at nearly 4lbs and burly with 35mm stantions. But your gonna pay the price for it.
    All in all, the closer you come to 150mm, the better your bike will climb. The lighter your fork (and bike) are, the better it will climb.
    -jm
  7. #407
    I just wanted to chime in again with my own personal experience, I'm 180lbs fully geared up, my fox van R is the 180mm model reduced to 155mm, I had to cut off about three coils from my medium-rate spring, and feel that it is no way oversprung now, I still use all but the last 10-15mm on all but the very most difficult trails i've ridden (@fernie BC this past summer, I came within a close couple mm's of bottom)
    I use a fox VAN RC on the rear with a 450# Ti coil spring (i used steel springs til I figured out what rate suited me best, then picked up this Ti coil off ebay for just under $100)
    Overall my 2011 plain reign is a pretty light XC build (2.3 tires, TL28 rims, XT/X9 drivetrain etc) EXCEPT for the fork and shock, and I still come in at 29.5lbs and only ever notice the heavy fork when hanging the bike up in my garage ceiling at home, ALL the riding time I have on it, it feels very neutral handling and balanced!
  8. #408
    Forgot to add, that I actually picked up my Van 180 to replace a 36 TALAS 160 that I thought felt HORRIBLE thru it's range of motion...
  9. #409
    May 2013
    Quote Originally Posted by htek View Post
    I REALLY appreciate the detailed advice, thanks!
    I am about 10months into riding frequently, so I am pretty new. I am not going to bike parks, I am not hitting jumps (yet?) I am also coming off an injury that sidelined me for almost 2 months, so I am slowly gaining back my confidence and I am not currently charging very hard on downhill type stuff.
    When I bought this bike I figured it would be better to get "more bike" than I currently need and grow into it rather than get "not enough bike"
    I have a nice XC bike (Airborne Goblin) that I love for climbing hills, but it does not inspire confidence going down fast downhill sections or rock gardens. I also didn't want to get something in the "trail bike" category for fear it would be too similar to my Goblin.
    It sounds like my best option at the time would be to get a smaller spring, suck it up and get better at climbing with the Giant.
    I have never had any work like this done. What should a ball park price be for buying a 160mm spring and then getting it installed?
    Thanks again everyone!
  10. #410
    May 2013
    Quote Originally Posted by onespeedpaul View Post
    ....only ever notice the heavy fork when hanging the bike up in my garage ceiling at home, ALL the riding time I have on it, it feels very neutral handling and balanced!
    I am about 245 fully geared up. I think I need to look into the rims and tires as well. I am pretty new to the upgrade/component world so thanks for bearing with me.
    I don't recall what rims are on the bike off the top of my head, I'll check this evening and report back here.
  11. #411
    Jun 2010
    At 245, sticking with the 36 isn't unreasonable. If you were a small guy, I would say the 36 is overkill... Not the case here.
    No idea on the cost... Sorry.
  12. #412
    May 2013
    Just contacted a local shop, who then contacted FOX and was told "those are not convertible in travel"
  13. #413
    Jun 2010
    Never owned a Fox fork, so I can't say for sure - but I'd be floored if you couldn't drop a 160mm spring in... even if Fox doesn't officially endorse it.
    I'd search the Suspension forum and I'd bet you might find your answer.
  14. #414
    it is my experience that fox will almost always recommend sending anything to them for repair and to not modify any product of theirs in any way....thank god/allah/theflyingspaghettimonster for liability and all that...
    that said, you can buy a new spring direct from them for $25 +shipping or buy one off ebay, or cut the one you have....
    there are plenty of tutorials here and elsewhere online showing with pics how to reduce the travel on many forks, and they are all almost the same procedure, which is remove the spring side shaft and put a spacer or spacers under the top out plunger.
    the only diversion from what is essentially the same procedure for most all forks is now your coil spring will be too long, so before using a powered cut off wheel, just measure it a few times, put it in a vice and zip it off....I get all fancy with mine and cut it a coil longer, and use a mapp torch to heat the tip and bend it flat, then shave it square and flat like the way it is delivered....really tho, you can just cut it off and use a flap-sanding disc to make the cut smooth....
    hope this helps...I've done a few of my own and a few for friends, if you were local I would help you out too....
  15. #415
    you should check a dual position coil Sektor.
    it's a great fork, reliable and plenty stiff for a 32. it has adjustable travel, compression adjust and you can upgrade damping to the fancier revelation options if you get the Gold one.
    it is priced modestly as well.
    Lyrik is definitely nicer. I own both, but Lyrik can't match the bang for the buck you get from Sektor.
  16. #416
    Jul 2013
    2012 Giant Reign 2 upgrades
    I've upgraded a few things, Spank Oozy Evo wheelset, tubeless, XT drive train, Spank Oozy stem, Spank Subrosa bars, saddle, Odi Rogue grips.Giant Reign Modifications (Not Reign X)-picture-1591.jpg
  17. #417
    No Stranger to danger....
    Reputation: Tone's's Avatar
    Quote Originally Posted by Brewza View Post
    I've upgraded a few things, Spank Oozy Evo wheelset, tubeless, XT drive train, Spank Oozy stem, Spank Subrosa bars, saddle, Odi Rogue grips.Click image for larger version.
    Nice model mate, imho the nicest looking reign ever put out, but i would say that, ive got the same lol, im just a sucker for flat black, just looks slick...
    Dont ever let the truth get in the way of a funny story....
  18. #418
    And finally/most recently, I removed 5mm from the bottom of my head tube to get the steering angle as close to where I want it as it's going to get with the longer fork and bigger 650b front wheel....
    Hi mate - just wondering how you did this? I am looking to do the same so I can fit a tapered Revelation that I already have on my '08 Reign which has a straight steerer.
    The fork is about 8mm too short once you put the bottom external adapter cup (as discussed on here previously) in. I figure if I can get a few mm reamed from the top and bottom of the head tube I'll be able to get away with it!
    Did you have a go yourself or take it to a shop with a head tube facing tool?
    cheers,
    jezza
  19. #419
    Reputation: COMMandrew's Avatar
    Aug 2013
    I picked up a 2013 reign 2 just over a week ago for an absolute bargain. The kid I got it from had put on a standard seat post and BooBars + put high roller 2s on it.
    After a week with me (4 rides later);
    DT Swiss e2200 wheels (front not currently installed as am waiting for adaptor kit)
    Fox DOSS seat post
    Shimano Saint M810 brakes
    Shimano Zee derailleur
    Am currently testing bar width/stem length combos as the frame is a touch shorter than I usually go for but the advantage is the smaller the bike, the easier to throw it around. Once I have the bar/stem sorted, I will be replacing what I currently have (as those parts have come off other bikes lol).
    I also have a RS vivid air (2.25 stroke) in the post.
    Am still trying to find a decently priced set of 160mm forks though. Am half tempted to go to 170mm but I think that will throw everything out too much.
    Australia didn't drift away over thousands of years - Chuck Norris roundhouse kicked it in the face.
  20. #420
    Any help here? I found a deal on an older Monarch 4.2. It's listed as having the B tune. Is this the tune the Reign needs?
  21. #421
    Dec 2013
    after 1 year and half I decided to change some bits for my 2011 Giant Reign 1.
    I've signed for couple of gravity enduros and superD races and I wanted something more enduro-like, so here are the changes:
    Fork: Marzocchi 55 RC3 Ti 170mm
    F Wheel: Mavic 321 28mm
    F Hub: Hope Pro 2 20mm
    Handlebar: Giant 750mm (from my DH bike)
    Grips: Odi Lock-on
    Brakes: Shimano XT F&R
    Rotors: Shimano Ice Tech 180mm F&R
    Chainring: Wold tooth 32t
    R Derauiller: Shimano SLX Shadow + (w clutch)
    Tyres: Specialized Butcher Control 2.35 F&R
    Chain: Shimano
    Seat: Ks Ten hydraulic 125mm w remote
    Lucky me when I bought the bike it was on super-sale as last model of year before so I got it for 50% of listed price... with these adds-on i practically spend another same, so pretty happy with this
    and thats how it looks like:
    Giant Reign Modifications (Not Reign X)-image1.jpgGiant Reign Modifications (Not Reign X)-image2.jpgGiant Reign Modifications (Not Reign X)-image3.jpgGiant Reign Modifications (Not Reign X)-image4.jpgGiant Reign Modifications (Not Reign X)-image5.jpgGiant Reign Modifications (Not Reign X)-image6.jpg
  22. #422
    Quote Originally Posted by greatbigjezza View Post
    cheers,
    jezza
    I really don't think there is enough material to remove on the older straight 1-1/8 frames. I would advise getting a fork with a longer steer tube.
  23. #423
    Finally rid of the awful RP2. Got a RockShox Kage RC. Darn website/computer/operator won't upload.
    in Ogden, Utah, United States - photo by bikeboardorblade - Pinkbike
  24. #424
    How do you like that new shock?
    I run a VAN RC with a ti spring on mine and it was a big improvement, BUT i'm thinking of trying an Xfusion Vector coil HLR...
  25. #425
    Unfortunately I haven't been able to put any real time on it yet, just some manuals in the parking lot. Most everything here is snowed in, I'm hoping to make it out within the next couple of weeks. I'll be sure to report on it though.
    I think the Vector would be a great choice, with the added adjustability. If I could have gotten one with my budget I likely would have.
  26. #426
    Reputation: jb2011's Avatar
    Jan 2011
    Hey Guys I have a Reign 2011 model & I'm thinking of upgrading the shock,two questions has anyone upgraded from RP2 to new Fox CTD Kashima? If so thoughts?Second question I always understood that the size of my shock on 2011 model is 7.875 x 2.0 for shock but when I measure stroke its 57mm...can anyone confirm that it's a 7.875 x 2.0 as standard? As I'm really confused why I'm measuring 57mm
    Life's too short to be soft
  27. #427
    If its of any help I switched my 2011 to a 200x57 shock. The eye to eye on both are the same, so you can use either 200x50 or 200x57. Switching to the 57 spoke gives you about 3/4 inch more travel.
  28. #428
    Quote Originally Posted by jb2011 View Post
    Most 7.875x2 (200x50) shocks show 57mm on the shaft, BUT if you let ALL the air out and fully compress the shock you will see that it only uses 2" (~50mm) leaving the final .25 (~6-7mm) exposed unlike the 2.25 (57) shocks which when compressed fully cover the shaft...Hope that helps!
    **late edit** IF it is the case that your shock does travel the full 57mm, (2.25) then great, upgrade it with either size of your choice! I personally upgraded mine with a 7.875x2.25 fox VAN RC w/ti coil...
  29. #429
    Jan 2011
    Thanks this makes sense, good deal on a 7.875 X 2.00 so worth giving it a try i think. Do you notice the extra travel ? Any positives or negatives?
  30. #430
    It's a subtle difference with no negatives...In my opinion using the 2" stroke shock has slightly more perceptible pop off bumps, and using the 2.25 feels slightly more bottomless, so I look at it as more of a matter of tuning the bike to how I like to ride (XC/AM) and that's me preferring about 30% sag with good small bump sensitivity, high traction, and bottomless feel, so I choose 2.25 stroke on my Reigns...
  31. #431
    Mar 2012
    Posted this in another section too, but it might get a bit more attention here.
    Does anyone think a 2011 Reign can accept a rear triangle from a 2012-2013 reign x or perhaps from a 2013-2014 trance, trance x 650b?
    The purpose for asking is that i want to convert my 2011 reign 2 to 650b but still having enough room to install a 2.35"-2.4" tyre and also having a maxle back there.
  32. #432
    Mar 2014
    Hi everyone!
    Here is my Reign 2, 2013 with some modifications:
    - Rock Shox Lyrik RC2 DH, 170mm travel
    - Shimano SLX brakes, 180/180 rotors
    - FUNN FatBoy (760mm) and Funnduro (30mm)
    - Leonardi Factory General Lee wide ratio cassette adapter
    - Blackspire wide narrow chainring (32T)
    - Shimano Saint pedals
    - Selle Italia seat
    - Maxxis minion tyres
  33. #433
    Sep 2013
    Great bike. Are you happy with the Lyrik? Is it air or coil? I am thinking to buy one for my Reign as well.
  34. #434
    Reputation: I_AM's Avatar
    Mar 2013
    Looking to upgrade the rear shock on my Reign 2 to a spring shock. Any recommendations and what size am I looking for? Thanks.
  35. #435
    I recently put the RockShox Kage RC on, in the 200x57 option, and I love it. I have a 2011 Reign, and it has been a big improvement. As others have noted it isn't as poppy, but it tracks sooo much better and seems to use is travel much more efficiently. The Reign wasn't made to race uphill to begin with, but I don't feel it has negatively affected is pedalability.
  36. #436
    Mar 2013
    Thanks. How do I know which length to buy?
  37. #437
    Either the 200x50 or the 200x57 fit. The latter gives you about 3/4" more travel. Others here may have additional insight, but my suggestion would be if you are running a 150mm fork go with the 200x50. If you have a 160 or 170mm fork go with the 200x57. I think that will be more balanced.
  38. #438
    Mar 2013
    What is the eye to eye length? 7.875?
    EDIT: NVM found it.
  39. #439
    200 or 7.875.
  40. #440
    Mar 2014
    Quote Originally Posted by Paris Galanis View Post
    I'm very happy with the Lyrik. It's an air fork. Some people say coil is better, but I haven't ride it yet. Overall it's a great fork for that money, especially if you're buying an used one.
  41. #441
    Sep 2013
    Quote Originally Posted by Sadida View Post
    Thank you. I am still between air and coil since there are pros & cons in both options.
  42. #442
    Dec 2005
    Quote Originally Posted by I_AM View Post
    Before considering coil (don't get me wrong they have been reported to be very good on the Reign), look at replacing the stock Fox shock with a better one.
    I went through the Fox RP2, RP23, then had the RP23 tuned, in the end a stock Monarch Plus RC3 was better, and better again is the X-Fusion HLR Air. Never try the Cane Creek, but most seem to report excellent performance with it.
    Good luck and have fun upgrading.
  43. #443
    bacon! bacon! bacon!
    I'm going to disagree with the shorter fork/shorter-stroke shock "balance" advice. Go with the longer stroke shock. There is no downside really - the i2i is the same so the geometry is *exactly* the same between the two. The only difference is more travel. And who doesn't love MOAR TRAVEL?
  44. #444
    There are definitely pros and cons.
    Biggest pros for me were:
    Better performance (perhaps perceived?)
    Simpler (no effing with the shock - I like that)
  45. #445
    Sep 2013
    Quote Originally Posted by SkaredShtles View Post
    Yes I agree.
    I prefer the coil for the reasons you mentioned but the air Lyrik and Vivd will be lighter and easier to adjust since I wont need to change coils to try different settings.
    I currently have a Domain and Kage (both coil) and despite the fact that they have only some basic settings I really like then but I would like to have more settings to fine tune the bike's performance.
    Anyway I am still thinking about it.
  46. #446
    Yes I agree.
    Yup - these are definite cons.
    I've got a simple old Fox Van-R.
    Found a Ti spring in the correct weight and I'm happy as a clam.
  47. #447
    Sep 2013
    A ti spring is also an option I consider. My main issue with both the Domain & Kage is that they are the base R models instead of the RC so they don't have a compression damper.
    So currently there are 4 options.
    1. Keep the fork & shock as they are and save my money.
    2. Internally upgrade Domain to RC and buy a Kage RC for a total cost of 300 euros for both.
    3. Buy a Lyrik and Vivid both coil for a total cost of 1000 euros.
    4. Buy a Lyrik and Vivid both air for a total cost of 1150 euros or a Lyrik and Monarch Plus for 1.000 euros.
    The good thing is that there are a lot of options available but I am afraid that I am close to the "paralysis of analysis" effect.
  48. #448
    So option #1, then?
  49. #449
    Sep 2013
    So option #1, then?
    1 or 2 because I really need the low speed compression and 300 euros are really affordable.
  50. #450
    Damn you rich Europeans!
  51. #451
    Sep 2013
    I wish! They are affordable vs. the 1.000 euros that I need for the Lyrik & Vivid.
  52. #452
    Hey Guys,
    I bought a new 2013 Reign 0 which came spec'd with a float CTD adjust shock. Is it normal for the rear suspension action to NOT feel locked out with the float set to Climb mode, bouncing around in a parking lot? The fork, in comparison, feels locked out in climb mode.
  53. #453
    Mar 2012
    Can i put this cassette (Shimano SLX HG81 10 Speed MTB Cassette | Chain Reaction Cycles) in my 2011 reign 2 to convert it to 2x10?
    Will i have to change the RD or it is possible to make any adjustment to the 9 speed X7 to play well with the 10 speed cassette?
  54. #454
    ***** lurker
    Reputation: cfanto's Avatar
    Oct 2010
    Sorry to say, you will need to purchase a 10spd derailleur, as well as a 10spd shifter & 10spd chain.
  55. #455
    Mar 2012
    Thanks for the info. I thought that this was the case but you never know!
    Στλθηκε απ το C1905 μου χρησιμοποιντας Tapatalk
  56. #456
    Hey guys, I'm about ready to replace the blown out fox dhx air4.0 on my 2010 large reign 1.
    When I let all the air out of my stock 7.875 x 2.00 shock, the curved crossmember of the rear triangle comes incredibly close to the front derailleur cable on the backside of the seat tube. Everyone in this thead says a 2.25 just works without much detail. Have you bottomed out? There doesn't appear to be any extra room for anoth 3/4 inches of travel. Am I missing something? I know many moved the front derailleur up so the swing arm doesn't hit it. That's not what I'm talking about
    Also looking to go with a 10x135 mm bolt up hope pro II EVO. I haven't seen many people talk about this in this thread either. Seems like a no brainer upgrade as my stock Deore hub is crap. The added stiffness of the bolt up sounds awesome. Thoughts?
  57. #457
    Quote Originally Posted by xjrides View Post
    I tested my Fox Van-R without the coil spring on it and it went through full range with no problem...
  58. #458
    Dec 2005
    ...When I let all the air out of my stock 7.875 x 2.00 shock, the curved crossmember of the rear triangle comes incredibly close to the front derailleur cable on the backside of the seat tube. Everyone in this thead says a 2.25 just works without much detail. Have you bottomed out? There doesn't appear to be any extra room for anoth 3/4 inches of travel. Am I missing something? I know many moved the front derailleur up so the swing arm doesn't hit it. That's not what I'm talking about
    As already noted, you should test it out before riding. I am pretty sure my Vector HLR Air is a 7.785 x 2.25, I did have all the air out of the main chamber and fully cycled the shock to see if it would have any contact. If I remember correctly I had to slightly move the front D out slightly so it wouldn't hit the rear arm on the triangle.
    For the rear wheel/hub, yes that is the my main complaint on the Reign. It really should have a 12 x 142 or something like it. I have a 135 x 10 Thru-bolt and use the DT Swiss RWS thru axle. Big difference over a standard QR with the skinny little skewer.
    Have fun with the mod
  59. #459
    Quote Originally Posted by rideitall View Post
    I will also use the rws dt swiss 10mm thru bolt. Pumped about that.
    I'm thinking of going with the monarch plus rc3. I don't need a coil on this bike as my build is already at 31.5 lbs. the glory handles the coil shock needs. I guess from reading this I need to search for a medium tune.
  60. #460
    Dec 2005
    The RC3 Plus is great, I like it better than the RP23, depending on the riding you are doing, the X-Fusion Vector HLR Air is a step up, handles the rougher terrain better.
  61. #461
    Apr 2014
    I have a 2012 Reign 1. No major changes yet but I just swapped the tyres out for a Minion DHR2 rear and High Roller 2 front in 26x2.4 - only slightly bigger than the tyres that came on it, but seems to be heaps more volume.
    Where I ride "grows rocks" so I also put on a carbon frame protector I got off ebay that has already paid for itself a few times over.
    Future mods will be tubeless tyres, and better brakes. For now.
    I've been curious about a bigger rear shock, or even a coil in the back, so will be reading back through this tread.
  62. #462
    Reputation: DannyHuynh's Avatar
    I have a 2012 Reign 2. I am now going to get that DT Swiss 10x135 thru bolt. it should just plug and play into the stock tires that came on the bike right?
    I also ultimately want to put a 170 Lyric with DH damper and a New rear air shock with the longer stroke, maybe an angle set to slack her out a bit more. I basically want to make my reign a park.FR bike.
  63. #463
    Reputation: YJGUY's Avatar
    Mar 2005
    Iím in a similar situation. Thinking about upgrading to a Cane Creek DB Air rear shock 7.87 x 2.25 but their customer service rep has just told me that it wonít fit. The extra bit of squish would be nice but I donít want to spend $600+ on a shock that I canít use so Iím on the fence right now.
  64. #464
    Jul 2013
    Thomson X4 1.5 stem on 2013 Reign 1
    Thomson X4 1.5 stem on my Reign 1.
    Giant Reign Modifications (Not Reign X)-photo-1.jpgGiant Reign Modifications (Not Reign X)-photo-2.jpgGiant Reign Modifications (Not Reign X)-photo-3.jpg
  65. #465
    Giant Reign Modifications (Not Reign X)-20140422_102848.jpgGiant Reign Modifications (Not Reign X)-20140422_102903.jpg
    Trying out the Rock Razor. Seems to be a pretty good rear tire. Rolls fast, bites pretty good on the sides. Still getting used to it, I could get away with about whatever I wanted with the Minion it replaced. Not the case here.
  66. #466
    Mar 2013
    Question for other Reign owners. I'm 5'6 in shoes with about a 30 inch inseam. I bought a medium because it was a great deal. After getting more experience riding I'm starting to think maybe the medium frame is a little tad bit large for me? Any others with experience? Thinking of moving to a small frame.
  67. #467
    Sep 2013
    I am 6 ft (183 fm) and I also ride a medium Reign but I have a rather low inseam (83 cm). Coming from a large Fuel EX I feel the medium Reign to be more maneuverable but I believe that 6 ft is the final upper limit for a medium.
    In your case and considering that you are 5.6 ft a small frame could possibly have the same handling as the medium has for me.
  68. #468
    ***** lurker
    Oct 2010
    I'm 5'6 and love the stand over of my small 2011 Reign (even w/ the 650b), but have to run a 75mm stem just for reach... I was actually in the market for a medium reign so I can run a shorter stem... IIRC, the SO height between the small & med wasn't much of a difference
  69. #469
    Mar 2013
    Lets trade frames!
  70. #470
    Sep 2013
    Quote Originally Posted by cfanto View Post
    Can you post a photo of your Reign with the 650B wheels? What tire do you have in the back?
  71. #471
    ***** lurker
    Oct 2010
    Attachment 888419
    I'm running NeoMoto's front and rear
  72. #472
    ***** lurker
    Oct 2010
    Lets trade frames!
    What year is yours? Any pics?
  73. #473
    ***** lurker
    Oct 2010
    I've been wanting to replace the OEM wet-noodle Float 32 w/ a coil 35/36...
    Anyone know if the new gen Marzocchi 55's have clearance issues w/ 650b? Otherwise, my second choice would have to be the Vengeance HLR (170mm) w/ Van 36 (160mm) last on my list.
    Also, any issues with running coil front & air in the rear? ...at least till I can afford to replace the rear shocks... As the fronts are gonna set me back a bit.
  74. #474
    Sep 2013
    Attachment 888419
    Great thank you. What size are they (2.1, 2.2 etc)? Do you have any clearance issues?
  75. #475
    Hmmm... philosophically against getting a Pike?
    Glad to see I'm not the only one that thinks the long-travel Float 32 is really not up to Reign-type tasks and terrain. Thing is a frikkin' NOODLE.
    Nope.
  76. #476
    ***** lurker
    Oct 2010
    No clearance issues w/ the 2.3's front & rear... Though I'd eventually like to get a 2.4 or 2.5 up front.
    Here's a mud ride I did a few months back...
    Attachment 888471
  77. #477
    ***** lurker
    Oct 2010
    Nope.
    The Pike is actually first on my list if I go air spring... But they're pricey & haven't seen any used Pikes yet. Do you know how it compares to coil? Does it have the same small bump suppleness?
  78. #478
    Oct 2010
    Are you running the original float 32 with the 27.5 tire in the front? Also any modifications to the rear to put the 27.5 in the back?
    2016 YT Capra
    Ash Caynon
  79. #479
    ***** lurker
    Oct 2010
    Quote Originally Posted by Hotwhls View Post
    Yes, I did run the stock fork w/ the 27.5 in front. As you can see, there was still plenty of clearance:
    Attachment 891575
    No modifications were necessary to fit the 27.5's... front or rear. I just slapped them in & rode them. I did take note from another forum that recommended NeoMoto's for the rears. Someone had attempted to run Nevegal 27.5's... and while they fit fine in the front, the rears rubbed. From what I understood the Nevegal 2.35's are a tad bit taller than NeoMoto's 2.35's.
  80. #480
    ***** lurker
    Oct 2010
    Reign w/ a Vengeance!
    Got my Vengeance HLR Coil! I need to get a ride on it to see if I stilll need to reduce the travel down to 160mm... but I'm hoping to keep the whole 170mm. I'm just concerned about how it's gonna feel climbing hills.
    Unboxing:
    Attachment 891579
    Attachment 891580
    Note the straight steerer - I couldn't find any (new) tapered versions for under $500 so I just ran an FSA crown reducer and fit it into the Reign's tapered headtube:
    Attachment 891581
    Substantial beefiness!
    Attachment 891582
    Attachment 891583
    Attachment 891588
  81. #481
    Mar 2013
    Sweet! How is the Xfusion riding? I just put a Lyrik on mines but didn't get a chance to go ride yet.
  82. #482
    ***** lurker
    Oct 2010
    It was sweet! I took it to Soquel Demo Forest last weekend. It was very confidence-inspiring. It just ate up all the drops & sketchy rock garden sections. Climbing on it was no problem, neither. Though I had to slam my stem all the way down to the headset to accommodate the higher A2C. I also thought I'd be (internally) reducing the travel to 160mm, but I love it the way it is (@ 170mm).
    It's funny to hold up my old Fox Float 32 - it just seems like a toy - lol
  83. #483
    Mar 2013
    Nevermind I was able to find what I need.
    Got a brand new 2011 Reign 0 frame coming from the dealer! Pictures coming when I get the frame and build it.
  84. #484
    Visited Santa Cruz and rode SDF this past weekend. Did ridge -> saw pit trail and back up the fireroad. Towards the end of saw pit the rear suspension stiffened up significantly like a huge increase in spring rate. I pulled over and the rear shock was warm to the touch. Bike was stiff when trying bounce on it at the top of the travel range. Did the shock over heat? Have you experienced this on these trails? Sorry for the noob question
    The shock is stock 2013 LV float ctd-adj set to descend.
  85. #485
    ***** lurker
    Oct 2010
    Quote Originally Posted by mobilenemo View Post
    No, I've never had any issues w/ my stock OEM Fox Float RP2...
    We did the exact same route... Ridge -> Saw Pit -> Hinh's Mill Rd.
    But then again, I was with a group, so we stopped every so often to regroup.
  86. #486
    I've heard rumors of air cans overheating... but never experienced it myself. 'Course now with a coil I won't have to.
  87. #487
    ***** lurker
    Oct 2010
    Hey SkaredShtles, which coil are you using & how does it affect suspension bob when pedaling uphills?
  88. #488
    hmm i guess i have to do more testing at the local bike park this summer
  89. #489
    Mar 2013
    Today is a bittersweet day. Last shot of my 2011 Giant Reign 2. First full suspension bike I ever owned and it was a good bike to me. I loved it to death.
    The new frame: 2011 Giant Reign 0
    A small and medium frame side by side.
  90. #490
    May contain nuts
    Reputation: Haggis's Avatar
    2011 was too big?
  91. #491
    Mar 2013
    They both are 2011's. The medium was just a tad bit big I'm only 5'6.
  92. #492
    Mar 2013
    Anyone running clutch derailleur with narrow chainring? How are drop issues?
  93. #493
    Been running that combo for close to a year now, everything from dirt jumps, the bike park, and some incredibly rocky trails and have yet to drop a chain. Dropped it more when I running a full guide.
  94. #494
    Mar 2013
    You're running a Zee derailleur?
  95. #495
    Yep. Zee and the Race Face Narrow Wide. Awesome combo.
  96. #496
    May contain nuts
    Narrow wide and XT medium length - still get the odd drop
  97. #497
    Doesnt ride Banshees
    Reputation: Banshee Rider's Avatar
    I ran an XO crank with a North Shore Billet spider and XX1 chainring on mine. Never had a chain drop with the XO type rear derailleur. Sadly, its now up for sale, for anyone who wants a fresh Reign frame in a rare color
    Giant Reign in rare color, Lyrik RC2 option, Photos - Classifieds
  98. #498
    Reputation: Iboated's Avatar
    May 2010
    32T RF NW and a Sram x9 type 2 and yet to drop a chain..
  99. #499
    Reputation: SkiDeep's Avatar
    Jun 2014
    Hey everyone. New to the Forum, and just getting back into mountain biking after 14 yr hiatus or so.
    Just got a used reign 1 at a fair price. I have put quite a few miles on it, and I am looking to upgrade it. It is just fine as is, but I feel it has even more potential.
    I have been doing mostly all mtn, bike park and light lift serviced stuff. Going over this thread can be a bit overwhelming with all the different generations mixed, and which years cross over which etc.
    I bought the bike, it was advertised as a 2010, but i believe it to be the 09 (very dark midnight blue, gold accent pieces. I don't think the owner was trying to pull a fast one, just didn't know, was a fortunate owner of multiple bikes.
    I am looking for a point in the right direction, would love to beef of the suspension
    to 160mm-170mm up front, I want something stronger in the rear as well.
    Some questions I have are
    1 am I limited to straight steer up front? or is there easy way to convert to tapered? (I've read conflicting reports and only one post on teton gravity research that talks about botched modification)
    2 What are my options for rear shock? It is a size L I am not concerned about weight, I would love a bit more plush decent. 5'11" 215lbs
    Thanks for any help and info, any links to exact parts, models, classified ads I should consider would be a huge help.
    I read as many threads as I can to become informed, but it seams, the suspension market is constantly changing and I just want the best bang for my buck.Name:  reign 1.jpg
  100. #500
    Cliff's Notes:
    Get a 2.25" coil for the rear shock
    You *are* stuck with the straight steerer - get a 160mm Lyrik with a straight steerer.
Members who have read this thread: 31
