Page 21 of 29 FirstFirst ... 11 17 18 19 20 21 22 23 24 25 ... LastLast
Results 501 to 525 of 709
  1. #501
    Reputation: bikeboardorblade's Avatar
    The Lyrik and 2.25 shock have been great for me. The X- Fusion Vengeance is also available with a straight steerer tube.
  2. #502
    gravity fighter
    Reputation: Mikecito's Avatar
    For fun, i put the front wheel from my new Troy on my 2012 XL Reign 2. 650b with a 2.35 Hans Damph has room to spare.
    When I have some money to burn, I think a new wheel set will make this thing a monster truck :-)
  3. #503
    Update picture. Finally ditched my crappy 36 Vanilla R. Wanted to go with a Vengeance, but ended up getting a Lyrik RC2L DPA.
  4. #504
    May contain nuts
    Reputation: Haggis's Avatar
    Giant Reign Modifications (Not Reign X)
    What was the problem with the Vanilla 36?
  5. #505
    Quote Originally Posted by Haggis View Post
    Nothing really. Worked just fine. Just wanted something with more adjustability. Hands down, the Lyrik out performs the Vanilla though.
  6. #506
    I highly recommend upgrading the damper to the DH damper. Sooo smooth.
  7. #507
    Reputation: I_AM's Avatar
    Mar 2013
    Quote Originally Posted by bikeboardorblade View Post
    Interesting. I have a Lyrik Solo R. Would this work?
  8. #508
    Mar 2013
    What crankset works on a 2011? Is it the 83mm? Thinking about an upgrade. Does the Z crankset work?
  9. #509
    Nice thread. I have had a 2013 Reign 1 for just over a year from new. Mods so far are - tyres - HD 2.35 Front and Nevegal 2.3 rear. 785mm Funn Fatboy bars. 50mm Giant AM stem. 1x10 drivetrain with 34 RF Narrow Wide ring. Rear shock stock bar the biggest air can reducer Fox make installed. Fork - stock but serviced adding more and heavier weight lube oil to lowers and some float fluid to the air spring to reduce the air volume - now runs at 70 psi and does not bottom out too easily in descend mode.
  10. #510
    Quote Originally Posted by I_AM View Post
    I would assume so, a call to Sram to confirm it would be worth it though.
    The zee has been awesome for me. Loaded up I'm about 180 and can't detect any flex. The Reign uses the 68/73 version. Only downside is the finish wears off super fast, especially if you ride anywhere where there's sand or the dirty turns gritty with any moisture.
  11. #511
    Mar 2013
    First. I want to thank everyone in this thread for answering all my noob questions. Its awesome just seeing everyone's passion for the Reign. I eventually ended up selling my 2011 Giant Reign 2 frame and got a new 2011 Giant Reign 0 frame from my LBS. I transfer the crankset and brakes over but will slowly upgrade as I go.
    Frame comparison
    The new build
    Went with a Lyrik R. I didn't get the lockout as I kept forgetting to unlock on descents on my Fox 32.
    Shimano Zee RD, Race Face Narrow Wide 34, Deity Compounds
    Race Face 740mm, Odi Rogues, Rockshox Reverb
    Got a good deal on these Shimano XT Wheelsets
    Giant Reign Modifications (Not Reign X)-new-reign-resize.jpgGiant Reign Modifications (Not Reign X)-settingsun.jpg
  12. #512
    ***** lurker
    Reputation: cfanto's Avatar
    Oct 2010
    Frame comparison
Name:	Side by Side.jpg
    The new build
Name:	New Reign Resize.jpg
ID:	904292Click image for larger version.
    That's sweet!
  13. #513
    I'm just getting back into riding and have been piecing together a new bike. I just bought a reign 0 frame I'm putting together with a vengeance hlr dla a wheelset I laced up with dt swiss hubs and a sun inferno 31 and intense 30 and xo drive train with an afterburner 2◊10 crankset
  14. #514
    Jun 2014
    Hey guys,
    Looking to change up the fork on my 2013 Reign 1. I'm pretty new to mountain bike parts configuration and looking for some help. Trying to figure it out on my own but it's somewhat of a headache.
    I believe this requires me to get a new hub, stem, spacers, headset and a head tube reducer for the top.
    Am I missing any parts?
    You can buy a new fork without having to replace anything else as long as you pick one that works with what you have. If a shop told you that you need to replace all of your components they are lying to you.
  16. #516
    Jun 2014
    I'm trying to buy a used fork but from what I have read Giants head tube taper is not traditional (1 1/4" rather than 1 1/8"). This size issue makes it somewhat hard for me to find the right fork and why I'm trying to get those parts. Also the 2013 Reign 1 comes with a 15mm QR and I'm looking to get into the 20mm T/A forks which is why the new hub.
    I could be totally wrong about this just trying to piece everything together before I spend $$.
  17. #517
    You are correct, you do need a number of new parts. You can get away with just the upper headset, and there's probably a reducer available. (1 1/4 to 1 1/8).
  18. #518
    You can get a new xfusion vengeance on ebay with a tapered steer for 400ish
  19. #519
    Jun 2014
    hmmm thanks for the help guys think I have it figured out.
    Cane creek makes a cheap alternative to reducing the upper headset diameter rather than buying a whole new headset.
    Wish Giant didn't do this I honestly would be fine with the "30%" less stiffness they claim so I didn't have to buy all new parts. House brand hubs have no conversions either
    Oh well you win some and lose some
  20. #520
    ... and if we just ...
    Here's my 2013 Reign 2.
    some upgrade over wear and tear stuffs like dropper, RD, FD.
    Giant stock dropper is crap.
    Looking forward on better fork and shock
  21. #521
    Mar 2013
    I really like the color of the 2013.
  22. #522
    Oct 2010
    That looks like a Spike Spank stem what size is it. 35mm or the 50mm I just ordered the 35mm red for my 2011 Reign. I had a 70mm and I wanted to try something shorter. How do you like the stem?
    Quote Originally Posted by chyu89 View Post
    2011 Giant Reign
  23. #523
    Quote Originally Posted by Hotwhls View Post
    Yeah, it's a Spike Spank 50mm. So far fit just fine for me.
    Poor thing about the stem is the top cap, it breaks when you tighten too hard or fairly hard. I broke mine few times of tightening, the material is very thin. Have to use stock top cap.
  24. #524
    Oct 2010
    So I just ordered a Spike Spank 35mm stem for my reign. I have the Answer 780mm DH bars. I had a 70mm stem with these same bars and I just wanted to try something shorter. Is anyone else running a 35mm length stem on there reign or am I crazy going this short?
    2011 Giant Reign
  25. #525
    I'm running a 40, with a 780 bar. Love it. I would have gotten that same stem buti found mine for $15.
