• 10-30-2012
    VERT1
    Giant P-XC29er 2 and S-XC29er 2 weights
    Anyone know the weights on these wheelsets?
    I am after weights on bare wheels no tires, Q/R or cassette etc
  • 10-30-2012
    jclyle
    There is a thread on here on these Giant wheel sets.. I cant find it now. I believe the SXC29 weight is around 2000-21000 grams.
  • 10-30-2012
    jclyle
    Here is the thread. There are a few weights thrown around. I would like to see the wheels on a scale as I am considering going from S-XC292 to a Stans wheelset for tubeless.
    http://forums.mtbr.com/giant/giant-p...ad-675185.html
  • 10-30-2012
    VERT1
    I went through that thread before I posted but could only find referrences to the 26" wheels
    Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
  • 10-31-2012
    rapsac
    Front and rear, rim strip including, excluding all else.
    Edit: 29er wheels...
    Verstuurd van mijn GT-I9100 met Tapatalk
  • 10-31-2012
    jclyle
    RapSac - what size are those wheels? Thanks for the pics!
  • 10-31-2012
    Cotharyus
    They're 29" - you can see it on the rim in the first picture.
  • 10-31-2012
    jasmorg1075
    I am sure the following is pretty close for the PXC-2 wheel set. Originally posted by scyule on The Giant PXC-2/SXC-2 Wheelset thread:
    P-XC 2.....weight.
    Front wheel with rim strip ( without 15mm thru axle).953 grams
    15mm thru axle 71 grams
    Rear wheel with rim strip 1215 grams
    Rear quick release 63 grams
    I just upgraded my 2011 Giant AX3 29er from the SXC-2 to the PXC-2 and they seem to roll much faster and a bit lighter. The shop I talked to said they are a really good wheelset and very close in weight to the Stans Flow wheelset. The PXC-2 were much cheaper as well...got both wheels brand new for $100. I set them up tubeless with Bontrager rim strips/valve stem, stans, and Geax Saguaro. It was very easy to do and sealed right up with no leaks.
  • 10-31-2012
    VERT1
    cheers, thats some heavy wheels.
    FYI Stans Flow EX are 1890grams and Stans Arch EX All Mountain are 1685grams
  • 10-31-2012
    jasmorg1075
    Eh...at 6'4" and 250lbs whose counting grams...hahaha...seriously though I don't race, but love the sport and gets me my exercise to keep my wife off my back.
    Quick question about the weights on the Stans rims...where did you get those figures because the Stans wheelset calculator has them at much lower weights configured with hubs and spokes. Was the weight you have with tire, QR, etc?
  • 12-15-2012
    eruizela
    Wow, 2302 grams a set for the P-XC29, did not realize they where that heavy.
    P-XC 2.....weight.
  • 12-15-2012
    Bigfoots
    I think the stock hub in the sxc2 and pxc2 rims is kind of heavy.. I went with the x9 hubs since they seemed to be the best weight/performance/cost ratio... and they were a direct replacement as opposed to the xt hub. btw x9 hub is sealed cartridge and the xt hubs are ball and cone.
    I think I shaved close to 3/4 pound by switching from the stock sxc2 to the archex/x9/dt swiss comp spokes tubeless.. perhaps it was more ..but it was nearly a pound weight difference when all was said and done give or take a few oz
    EDIT:
    according to my lbs upgrading from my stock scx2 to archex/s9/tubeless knocked 1.6 pounds of my bikes total weight.
    so thats pretty significant. I do however think a large part of that weight reduction is just the subtraction of the tubes.. so even just making the scx2 wheels tubeless will help a lot and ride better imho
