Results 1 to 3 of 3
    Giant MPH 3 brakes
    i've noticed one strange thing on it. when pushing left lever (front brake) fast and releasing it fast, everything is ok. but when i'm releasing it very very slow, there's some squeak, it feels quite unsmooth. checked it on brand new Terrago - left lever feels absolutely the same. both mine and Terrago's right lever is very smooth. i dont get it - is it normal? how about yours (if you have)?
    Reputation: spangelsaregreat's Avatar
    Hi,
    I have had one of my MPH levers replaced by Giant with the same symptoms. Basically water gets into the chamber on the lever and it rusts and eventually siezes. My new lever appears to be going the same way and it is squeaking like yours.
    You can take it to bits and clean it out but it appears to be a bit of a design fault on the levers. My rear lever is fine, that said, so it seems to only happen to certain units.
    Regards
    well it's quite strange cause brand new lever has same sympthoms - as i said on 2004 Terrago, tot. distance 0 miles (i was checking it in my buddy's store). how does it disassemble?
  1. new giant ranier avid disk brakes
    By kcs in forum Brake Time
    Last Post: 05-15-2004, 04:31 PM
  2. MTB Size, Giant DS 3
    By buckylb2121 in forum General Discussion
    Last Post: 05-07-2004, 06:51 PM
  3. Need advice on using disc brakes
    By moose in forum Brake Time
    Last Post: 04-05-2004, 11:18 AM
  4. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  5. My New Giant NRS
    By dgangi in forum Bike and Frame discussion
    Last Post: 03-02-2004, 03:58 AM
