Results 1 to 16 of 16
    Jun 2010
    Giant Dropper Seat post internally routed cable and housing installation…
    Hello,
    What is the proper technic to install the internally routed dropper seat post cable and housing on a 2013 Trance? The original cable and housing has been removed and now I would like reinstall it.
    Thank You,
    Dec 2013
    i too would like to hear from anyone that has internally routed their Giant dropper post internally !
    My dogs are barkin
    I think this is a well done how to on that seatpost...
    Ask a Mechanic: Assembling the Giant Contact Switch Dropper Seatpost
    Good luck!
    I know just enough to be dangerous
    --Me
    SoCAL
    06/17/2009
    Reputation: pablobell's Avatar
    Oct 2013
    Just went through this problem in the last couple of days.
    The solution for me was to seal up the frame with electrical tape and use a vacuum to suck string down the seat tube and out the cable hole near the bottom bracket. I then tied and taped on an outer cable to the string (with a greased end bent 1 cm in at about 70 degrees). Pulled the string to get it in to the correct corner position and then making sure the bend was facing the right way, pushed it down from the top through the corner and up to the exit point where I used a wire hook to pull it out.
    Dec 2013
    saw that video but it dont give any ideas as to the best routing of the cable....
    Oct 2013
    Did someone install on? Id like to buy an internally routed dropper post (reverb stealth or Giant) and looking for installation tips.
    Oct 2013
    Ok, just installed the Giant Contact Switch. I simply (not so simple) kept jamming the housing through the frame until it popped up the seat tube. Worked best when running the housing down the downtube then up the seat tube.
    You could also run a derailleur cable up the seat tube from the plug below the BBs, then run the other half up the downtube. Then push some housing through it.
    That worked on an 2014 Anthem
    I stupidly cut too much cable and have to buy more. Does anyone know what size cable to buy? Are there different mm ?
    My dogs are barkin
    Use a Shimano derailleur cable and housing, you will be all good. I recommend Shimano as I have found that they control the size of the barrel at the end of the cable very well. Occasionally, I have gotten a non-Shimano cable and had a very difficult time getting the cable barrel out of the switch mechanism.
    Good luck!
    --Me
    SoCAL
    06/17/2009
    Would you happen to have a good website to get it from? I looked on Pricepoint and only found brake cable. Can I use that?
    My dogs are barkin
    No to both, sorry. I would recommend going to your LBS and picking up the cable/housing you need. I am sure they will appreciate the business.
    Only a derailleur cable will work, a brake cable is larger in diameter and has a much different barrel than a derailleur cable.
    --Me
    SoCAL
    06/17/2009
    Reputation: DeArman's Avatar
    Jun 2014
    I just replaced the cable in my Contact Switch SL tonight and used Giant branded cable. We sell it for $3 a cable at the shop I work at. I've used both Shimano and Giant cables and housings and never noticed a difference between any of them. If you have a Giant dealer near you they should sell the same cable. They're cheap, work great, and you don't have to wait on shipping!
    Can I put the cable and housing internal through the frame with my 2013 Giant dropper post?
    Jun 2014
    What frame do you have?
    Jun 2014
    My bad, I see what your question is now, you're wondering if you have the version where you can flip the cartridge in the seat post to route it internally right? I honestly don't have an answer for that. If the stanchion is the gold(ish) one I don't believe you can run that one internally, but I'm not 100%. I think the internal option started on the updated, black stanchioned model.
    delete
  1. Jet 9 RDO Dropper Seat cable routing?
    By Ohfugit in forum Niner Bikes
    Last Post: 07-22-2016, 09:18 AM
  2. Replies: 2
    Last Post: 10-06-2013, 10:09 AM
  3. Replies: 7
    Last Post: 05-23-2013, 06:09 PM
  4. Internally routed brake housing - pros and cons
    By rasse1977 in forum Brake Time
    Last Post: 01-17-2012, 01:07 PM
  5. Internally routed cables
    By def156 in forum Frame Building
    Last Post: 03-18-2011, 03:00 PM
Members who have read this thread: 12
