Results 1 to 3 of 3
    Jun 2010
    Fox Float RP23 eye-eye length for '08 Trance X0?
    I am trying to replace the Fox Float RP23 in my gf's 2008 trance X0. It seems that the shock has a 7.25" eye-eye length, but a (Used) replacement RP2 shock that I bought from eBay seems to be a little longer 7.5". Is the correct stock shock length 7.25"? What will happen if I use the slightly longer shock?
    Oct 2013
    I remember seeing a pretty long thread in the Giant forum here about running a longer shock. If you search you should find it. I think someone found a replacement shock with the correct length as well.
    Mar 2013
    I found this to be the most useful thread in my recent quest to update my rear shock:
    another giant trance x to monarch rt3 upgrade Thread
    As noted in that thread, you'll need an offset bush for the upper eyelet of the shock - then you can run a 7.5" x 2". Most shock specialists will sell these bushes in the right size to suit the Giant.
  1. Float rp23 for trance x question.
    By kikoraa in forum Giant
    Last Post: 02-01-2013, 09:41 AM
  2. Fox Float RPL vs RP2 vs RP23
    By alexzhu1 in forum Shocks and Suspension
    Last Post: 10-25-2012, 03:55 PM
  3. TRc Fox RP23 CTD versus Fox Float RP23 CTD + K
    By Mercurial in forum Santa Cruz
    Last Post: 08-21-2012, 10:12 AM
  4. Trance X RP23 Boost Valve
    By hisbabyf in forum Giant
    Last Post: 07-27-2012, 10:09 AM
  5. Float R air sleeve on Float RP23?
    By will8250 in forum Shocks and Suspension
    Last Post: 03-04-2012, 06:11 PM
