Is it possible to convert the Fox 120RL fork on a 2009 TranceX2 from 120mm to 130mm by removing a travel spacer?
I know that this is possible on some Fox Float forks, they used to have a 10mm travel spacer on air piston side, when removed travel is increased to 130mm.
The next question: Is the Trance X a better technical trailbike with 130mm of travel up front?
