Results 1 to 3 of 3
    fork steer tube length required for reing X?
    looking at new and used forks and dont know what the length needs to be for the steer tube on the fork, I know the diameter is 1 1/8". 08 Reign X1 small
    thanks
    Quote Originally Posted by Black4esT
    thanks
    Can't you measure the original?
    I've got a Medium, the head tube is 5", the fork steerer is ~8.5", with about 1" of spacers, so compare your measurements - an 8" steerer should *just* fit, but 8.5" or more gives you some adjustment room, and will be easier to resell later.
    sweet, so a 215 mm steer tube should be ample for a small frame
    thanks fsrxc
