Results 1 to 2 of 2
    Reputation: DomN86's Avatar
    degree angle of this stem? Advice on new stem *+ other bits
    Hi guys,
    Anyone know the degree angle of this stem? It's a "GIANT A3 aluminium ahead", it has a reach of 80mm, and a height of about 5cm (measured by placing a ruler in the middle of stack height, then a tape measure from ruler to middle of handlebar bole = that is the correct way to measure it right?).
    I've never liked this stem, its ugly, and the angle looks ugly too. I've been thinking about getting a 'Thomson Elite X4 Stem (0' deg)', and buying a 30, 35, or 40mm riser handlebar, what you guys reckon? The current cockpit fits alright, so would like to maintain that.
    Also does the reach of a stem change depending on its angle? So if I was to replace my current 80mm stem with a Thomson 80mm, would the latter's reach be shorter? What would I need to make that up a 90mm?
    Lock-out:
    I currently have this lock-out on my fork;
    https://www.greyville.com/products/9...e#.UecADW0ueSo
    Anyone know if I can replace it with this lock-out, looks like the same size and mechanism;
    https://www.greyville.com/products/6552#.Ueb__20ueSp
    Tyres:
    I was thinking about replacing my 2.1 tyres with 'Continental Mountain King II 2.2' from eBay, but tonight I'm off the opinion I'll get a bit more out of my current tyres.
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Might be a 15 degree stem, going with a smaller raise angle will lower the bars but not shorten the stem lenght.
    Going from ~15 to 0 is quite a change, you may find yourself leaning to much forward, borrow and try before you commit or a you say get a higher rise bar to compensate.
  1. 100 mm -15 degree OPI stem?
    By the_marsbar in forum Cannondale
    Last Post: 01-25-2013, 06:12 PM
  2. looking for a -25 degree stem
    By pernfilman in forum Weight Weenies
    Last Post: 06-17-2012, 06:56 AM
  3. What Degree Stem if....
    By LowOnO2 in forum 29er Components
    Last Post: 03-26-2012, 06:51 AM
  4. Replies: 4
    Last Post: 03-02-2012, 07:49 AM
  5. 25 degree stem?
    By Esben in forum Weight Weenies
    Last Post: 02-09-2011, 08:31 PM
