    Creaky AC -- Help!
    Hi all,
    I have an AC3...rear suspension really seems to 'creak' a lot when riding...anything I can lube up? Can I do any damage by lubing the rear linkage? Any tips, what lube to use, if any?? Or is the creaking caused by something else perhaps?
    Reputation: bikeCOLORADO's Avatar
    Sep 2003
    Remove the seat post - clean inside the seat tube and the seat post. Put a very, very light amount of grease on the post and put it back in place.
    Remove the seat - clean the rails and the seat clamp assembly. Put a light amount of grease on the rails and re-install the seat.
    I rode and NRS and now ride an AC - this is fairly common with the way the seat post is shimmed.
    As far as the pivots themselves - taking apart the rear suspension is not that big a deal either. Remove the bolts, bushings/bearings and give everything a good cleaning. Do NOT use degreaser on the sealed bearings. Give the bearings a spin with your fingers, they should feel fairly smooth. If they're "crunchy" you might consider replacing them.
    "I may be old and fat, but at least I'm slow." - Me
    makes sense...
    Quote Originally Posted by bikeCOLORADO
    Thanks for the tips...it does make sense that that is where the creaking would come from...it didn't quite sound like it would be a noise coming from the rear linkage.
    I'll give it a shot.
    Worked!!
    Greased the seatpost before my ride and it got rid of the creak I was looking to lose...thanks for the tip..
  1. Chainguide on an AC
    By slo-rider in forum Downhill - Freeride
    Last Post: 03-25-2006, 04:02 PM
  2. what fork on our AC
    By bikeforlife in forum Giant
    Last Post: 05-27-2004, 05:37 AM
  3. Giant AC 2
    By Elite454SS in forum Giant
    Last Post: 05-23-2004, 01:46 PM
  4. AC sizing
    By avanti in forum Giant
    Last Post: 04-27-2004, 08:07 AM
  5. AC sizing
    Last Post: 04-13-2004, 09:20 AM
