Results 1 to 8 of 8
    Contact Giant or Fox?..bushings
    Need upper DU bushings for my 2012 x-2,noticed play after ride when lifting the bike by the seat,can feel slight play at the top of the shock ,everything else is tight.who to contact and is it a simple home fix. thank's
    Reputation: extremedave's Avatar
    The DU bushings are a standard size (I believe) and most LBS carry them. Or you could do the baller bearing set mentioned above (I might soon).
    I made a bushing press out of a couple chrome sockets and a big c-clamp, not at all hard to change them.
    Edit: I had a very similar issue. Turned out one of the lower shock mount spacers was undersized. Read about it here, skip to the last couple pages for pics and resolution.
    Weird shock mount issue...kinda long. - mtbNJ.com
    Not without incident.
    Thank you for the Info,very helpfull.
    I have the same think with both RP23 and Giant Shock. In my case tightening those red bolts helped. Anyway coul'd you please paste link to the spacers which you've bought for your Trance since i can't open it from your post on mtbnj.com?
    Ah. ended up ordering a lower bolt kit from a local Giant dealer. Comes with the upper and lower shock bolts, the spacers and a couple of the bearings. About 40 bucks. I think....maybe it was uk based chain reaction cycles had some of the kits online but I wanted to be sure I got the right set so bought local. The dealer actually got the wrong year kit 09 I think but everything was the same except for the lower bolt.
    Where can you order the complete bearing set for the rear suspension? I have a 2011 Reign frame...
    Quote Originally Posted by illegalsmile View Post
    Either the local dealer or:
    enduro
    Good thread here should apply to any maestro design:
    Trance Bearing replacement How To.
    Wasn't chain reaction it was these guys:
    Giant Suspension Frame Parts
