Results 1 to 3 of 3
    Carbon Anthem 29 vs Aluminum for low back issues? RS vs FOX?
    I have a medium 2013 Giant Anthem X1 29er and I like it. I am 190 LBS and by next year I should be down to 175-180 LBS. Bike has Fox forks and shock which are ok but not great. I can't ride a cx bike anymore bc the riding position is too bent over, and ride is too rough. I find as long as I am not careless and I take breaks to stretch, I can mtb on the 29er full suspension with big tires. I'm considering scooping a medium Anthem 29er Advanced bc the newer 2014 has Fox equipment and the 2013's can still be found for a good deal now.
    The Advanced 1 over my aluminum 1 is a lighter bike with lighter wheels, and it has better parts and RS suspension and should be stiffer laterally. Is the carbon stiffer vertically too? Is the carbon front triangle good or bad for my back? The RS suspension may not be as plush people say, but I think dialing it in and adjusting compression and rebound could allow it to work for me.
    So what's your take?
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I have a bad low back and going from an aluminum to a carbon frame was a big change. It really dampens the small vibrations and just makes for a nicer ride.
    14 Aurum, 16 Fuse, 17 T130
    Ok, I will seriously consider it as an option. I have been mtb'ing for years, but a couple of years ago, a car accident has made my low back not so friendly to jarring. That is part of the reason I went to a 29'er. Bigger wheels = smoother ride. I'm considering getting slightly bigger tires and a new saddle with bushings for cush. If a carbon frame is easier yet on my back then all the more reason to go that direction. That's what I'll tell the financial part of my brain anyways...
  1. Replies: 16
    Last Post: 10-09-2013, 07:40 AM
  2. 2014 Advanced Anthem 29er - no 1X?
    By starry in forum Giant
    Last Post: 09-14-2013, 05:38 AM
  3. Replies: 22
    Last Post: 08-09-2013, 12:01 PM
  4. Anthem advanced 29er
    By boboxx in forum Weight Weenies
    Last Post: 02-19-2013, 01:45 PM
  5. Replies: 4
    Last Post: 01-31-2013, 06:54 PM
