Results 1 to 8 of 8
    Reputation: tosa's Avatar
    cable rub spots on Anthem X Advanced 1 29er
    Are there any trouble spots on these bikes that I should put tape over to prevent any cable wear? I previously had a Jekyll on which the brake cable gouged the frame over time, hence I would like to be proactive in preventing these simple problems.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Every bike has cable rub spots. Get a sheet of frame protector stickers and go nuts. Put them anywher you think will be bad.
    I'm a mountain bike guide in southwest Utah
    davidcarson48
    Guest
    Re: cable rub spots on Anthem X Advanced 1 29er
    I stickered the poop out of it. Then after a few rides, you'll see which stickers need to stay and which you can remove.
    The internal cables seem to help some as there is less slap. But the left side of the head tube still needs tape due to the rear brake line.
    On the inside of the swingarm where the rear brake line enters is a bad one.
    Nov 2012
    my 2011 Anthem X 2 already has the clear prtectors in place..
    Oct 2012
    Right side of the head tube and both sides of my rear shock show heavy cable rub on my 2012 X 0.
    Nov 2012
    Quote Originally Posted by retrorabbit View Post
    I bought mine used. Maybe the clear protectors put on. Anyway they ate in place wherever the cables touch the frame.
    Reputation: jkirkpatri's Avatar
    Headtube, both sides, rear brake line down on the swingarm by the capilar.
    Lookup the ziptie mod, or buy a Giant/Jagwire wire spreader. This will spread your cables and leave the shock free of any rubbing.
