Results 1 to 53 of 53
    Apr 2013
    Building Anthem X 29 and I Need Input
    Hey all,
    I'm new to the community and I haven't had a new mountain bike since 1996. I loved my Rockhopper but I got hit while riding it last year and cracked the frame.
    So, I bought 2011 Anthem 3 frame and I am building it up. I don't have a ton of money to throw at it right now, but I'd like to get riding it by taking parts off of the Rockhopper and then upgrading later. So, for example, I am curious if I can use the crank from my Rockhopper and buy a new bottom bracket and use that until I am ready to upgrade the cranks? Does anyone know if this is possible? I don't know much about BBs or cranks, nor do I know what the Anthem requires.
    Another question I have is can I put 180 mm rotors on the front and back of this bike or just the front?
    As far as the build goes, I am planning to get an RT3 for the rear based on comments and reviews I have seen here. For the front I snagged a brand new Reba RL Dual Air for cheap for the front. I got some Mavic 719s with XT hubs also for very cheap. I intend to stick with my current x7 3x9 setup for now. XT cassette, BB7 discs with the speed dial 7 levers. So, I am super stoked for the build and look forward to hearing from you all.
    Jeff
    Apr 2013
    Bump, anyone have an answer about the Bottom Bracket for this frame?
    As far as the BB goes, no, it won't work. The Anthem uses a Shimano Press fit BB, which is used with the hollowtech 2 crankset. My suggestion would be to buy the new crankset (it'll come with a bb) and have it installed. You would need special tools to install it yourself.
    Apr 2013
    Quote Originally Posted by Kshawn View Post
    Bummer, I was worried someone was going to say that. I started researching BBs and how to install them and that's when I saw the press fit and knew it was going to be what the Anthem has. I was hoping to skate by without getting cranks initially. Oh well.
    Do you happen to know if I can put 180 mm disc brakes on the back?
    Ya, cranks can be expensive. I would just buy the regular deore ones if you're on a budget. And as far as the 180mm rear, I hate to be the bearer of bad new again, but I don't think it would work. Disc size is determined by frame, and generally a 160mm (6") rear rotor is standard. Often times you'll have a larger rotor in front and a smaller rotor in back, just because most of your stopping power comes from the front anyway.
    Edit: If you really want to run 180, you can probably find an adapter for it. But as is, no, I think 160mm is your best bet.
    Apr 2013
    Hey, thanks for the response man. I figured since the bike came stock (per Giant's website) with 180 front and 160 rear, that was the biggest I could go. It's no worries. I am sure with 180 up front and 160 out back I'll have plenty of stopping power. Just didn't want to buy 180 and find out the hard way that it won't fit.
    As far as the cranks go, if I have to buy em, I'll get something nice, probably go XT, but it'll slow the build a little bit, haha.
    Apr 2013
    Quote Originally Posted by magnato1 View Post
    Ok, here's another dumb question, how do I decide what crank length to get? I checked Giant's website and it doesn't say what the specified crank length on this bike is/was. I imagine this varies based on small, medium and large as well, yeah? Mine is a medium. Thanks.
    bikerbert
    Reputation: bikerbert's Avatar
    RaceFace makes good cranks across different price points too. I had a heck of a time finding the right BB fort Anthem 29er because of the press fit thing.
    I ended up with X9's and have been pretty happy.
    Cranks can come in 170 175 and 180. The only way to know what size you need is if you have super long legs, super short legs or average sized legs. 170 is for short, 180 is for long. And np, happy to help.
    Apr 2013
    Quote Originally Posted by bikerbert View Post
    Yeah, I was looking at the RaceFace cranks as well, but seems like going with Shimano will make the BB issue much easier.
    Do you mean that you got the TruVativ X9's or SRAM X9?
    Apr 2013
    Hmm, I have a 30" inseam. I wonder if that's an 'average' length leg, haha. I've seen that some of the cranks come in 165mm as well. I'm sure the crank length affects pedaling as well. I bet if you get shorter cranks, it's easier to climb, but longer cranks make it possible to really fly when pedaling hard or downhill. Anybody know if this theory is correct?
    May contain nuts
    Reputation: Haggis's Avatar
    Other way around... short cranks are easier to spin, but other less torque climbing...
    Reputation: PerthMTB's Avatar
    The Anthem uses a BB92 press-fit BB, but this can be either Shimano HT-II press-fit or SRAM GXP press-fit, depending on what cranks you want to use. So, if you want to use your existing X7 cranks, just buy a SRAM BB92 GXP press-fit BB (like this - SRAM BB92 GXP Team PressFit MTB | Buy Online | ChainReactionCycles.com) and put this in the Anthem frame. Fitting can be tricky without a bearing press and cups, so if you're not confident doing it yourself get LBS to fit.
    No problem running 180 or even larger rotors on the rear of an Anthem, just get the right adapter. Anthem frame uses post mount on the rear, so you want an Avid PM to PM adapter.
    davidcarson48
    Guest
    Re: Building Anthem X 29 and I Need Input
    I would think you'd want 172.5 or 175 cranks.
    Apr 2013
    Sweet, thanks for all of the helpful responses! 180 rotors all around will be awesome. I can't wait to get the thing put together, but I see it taking at least another month, grrr!
    Apr 2013
    Ok, so now that I know I have to buy cranks, I am thinking of going the 20 speed route. There seem to be ten speed and 9 speed specific cranks, at least according to pricepoint. So, my question is, can I buy a ten speed XT crank with 2 chainrings and use that with my 9 speed cassette until I can upgrade, or do I have to do it all at once? Also, does anyone know of a gear ratio calculator that will help me determine what my current setup is and how to basically match it with a 20 speed setup (currently 27)? Thanks all.
    You don't have to buy new cranks, you just need a SRAM GXP press-fit BB92 bottom bracket (like the one I linked to above) to use your existing cranks in the Anthem. I'm afraid some of the advice given above isn't correct. The Anthem uses the Press-fit BB92 standard, and both SRAM and Shimano make BBs to fit that standard - so you can use either.
    But if you want to buy new cranks then XT M785 2x10 would be an excellent choice. There's no difference between width of ring and spacing between rings of Shimano's 9 and 10 speed, so yes you can use it on your 9 speed system until you feel like upgrading the rest of the drivetrain. You might need to tweak the 9sp front mech a bit to get it to work with the 2x10 cranks though. And remember, new cranks will come with an external BB, so you'll still have to buy a separate Shimano BB92 press-fit BB even if you buy new XT cranks.
    Sheldon's gear calculator is a good place to start... Sheldon Brown's Bicycle Gear Calculator
    May contain nuts
    I'd get a XT or SLX triple (doesn't matter if 9 or 10-sp) and then you have the option of running 2+bash, which is my pref, or 3 rings.
    Shimano cranks are so much nicer to install/remove than any of the more primitive interference-fit designs.
    I find the new 26/38 Shimano ratios too high for my riding, much prefer 24/36.
    Apr 2013
    Quote Originally Posted by PerthMTB View Post
    You don't need to buy cranks, you just need a SRAM GXP press-fit BB92 bottom bracket to use your existing cranks in the Anthem - see my reply above...
    Perth,
    Sorry, my initial post was not 100% clear. I have X7 shifters and derailleurs, but I have the original Specialized Son of Strong Arm cranks on, believe it or not, the original bottom bracket from 1996. This bike has to have at least 5,000 miles on it, so I don't know how the BB has lasted this long. Anyways, like I said, I don't know much about BB's or cranks, but I don't think the old 1996 cranks will work with the SRAM Press fit GXP BB you suggested, right?
    Apr 2013
    Quote Originally Posted by Haggis View Post
    Hmmm, that's a good idea, then if I don't end up liking the 20 speed setup, I can easily return to 27 or 30. Is there a downside to this idea? I'm guessing you stick with shifters for 3 front rings, rather than 2? And the triple weighs more than the double?
    Ah I thought you had X7 cranks as well. Well, Ok then, new cranks it is And the Shimano XT are an excellent choice.
    As Haggis says, if you want to use a bash, or swap between 2/3 rings then get the M780 triple rather than the M785 double, which can't fit anything (bash or ring) in the outer position. However, it will come with a 32 middle ring which might be a bit small, so you'll have to think about buying a 38 middle ring as well...
    And, as above, either will come with external BB, so you'll have to get the press-fit BB extra as well.
    Starting to add up a bit...
    I've run both triples converted to doubles, and specific doubles, and there's not really any functional difference.
    Yes you can keep the 3x front mech and shifters, you just wind the limit screw in on the mech so it doesn't try to shift into the non-existent big ring. Once you've decided on double, you may want to invest in the proper double mech though, as it has a smaller cage, and as a result looks better and will give marginally better shifting, and contain the chain better on bumpy terrain. SRAM has double specific shifters, but with Shimano you just have a 'mode switch' on the front shifter to switch between 2x and 3x.
    Downsides? Well, as above, you'll probably want to buy a 38 middle ring to give yourself a decent range of gears. Shifting will be marginally smoother with a double specific FD, and it'll certainly look neater! Weight isn't a factor, as a triple without an outer ring weighs the same as a double, and a double and bash weighs the same as a triple.
    The way you're going, you might want to consider just buying a whole Shimano 10sp drivetrain If you shop around, and particularly look at some of the European online sites, you can get a complete 10sp SLX groupset (including cranks, shifters, FD & RD, chain and cassette) for about $300, and $400 for XT (prices edited as I found better ones!). It would save a lot of messing about mixing and matching old & new, Shimano & Sram, 9sp & 10sp. Go on - you know you want to...
    Apr 2013
    You sir (or miss, since your screename doesn't really indicate either way) must be the devil. Haha, of course I want to buy all that stuff at once! But, what I want most is to start riding the bike. So I am focusing on needs right now. I need a crank, bb, rear shock, headset and brakes. Then I'll do the fine tuning. But, just for further reference, where'd you find those deals?!
    Ha, yes I know its bad of me to dangle temptation in front of you, but I'm just giving you the justification, should you want to persuade yourself its worthwhile
    Anyway, in case you're tempted, the German online shops seem to be the best place to buy Shimano stuff at the moment. I don't normally like to recommend specific retailers, as everyone has their own preferences, and buying online from abroad isn't to everyone's liking - but here's an example from a company I've had good experiences with...
    SLX 3x10: Shimano SLX 670 Gruppe 3x10 ohne Naben Modell 2013 - BIKE-COMPONENTS.DE
    XT 2x10: Shimano XT 785 Gruppe 2x10 ohne Naben - BIKE-COMPONENTS.DE
    Reputation: BacDoc's Avatar
    Perth has good advice for your build. You could also try Jenson as they price match. I got SLX cranks for $99 from them and they price matched the UK site for XT brakes.
    The right 2X10 should give you all the gears you need but depending on where you ride a 1X10 can work too. After doing the 2X10 for a while I have gone 1X10 on my Anthem 29 and works great - plus no FD, shifter or cable to install/maintain. The Anthem 29 with the Maestro rolls over everything and think you will amazed at the ride especially compared to your '96 ride.
    Good luck on your build and be sure to post some pics!
    Apr 2013
    Hey, thanks for the info. Those prices are in Euro, plus 19% tax! I don't think it saves enough money, but thank you for the suggestions
    I've just got to take my time and build it right. I will certainly keep y'all up to date when I get some new parts and start the build. I'm sure I'll have a lot more questions.
    I did try Sheldon's gear ratio calculator and I read about gain ratio and gear inches, but I didn't get a good feel for how drastic the differences are between my current setup and what I will be potentially moving to. My main concern is going to be my climbing gear. I'll stick with my current cassette and if it's not enough I'll change to an 11-36.
    Thanks again for all the input. I'll keep ya updated.
    Yeah, those prices are in Euro, but they include 19% German sales tax, which is automatically subtracted when you get to the checkout and put in the delivery address as being outside Germany.
    So, using the SLX gruppo as an example - Their price is Euro 295 incl. tax. Subtracting the tax gives Euro 248. This is approx US$316 at today's exchange rate. Haven't seen many complete SLX groupsets around for that, and remember these guys supply proper retail spec in the packaging with all the extra bits & pieces, unlike a lot of the 'cheap' online/ebay retailers.
    Anyway, just an option for you, there's more to consider than just price anyways - Germany is a long way to send things back if you make the wrong choice or something breaks!
    Remember 11/36 cassette is only available in 10sp, so that will force you to convert to 10sp anyway as you'll need 10sp RD, shifter, chain etc. to go with it.
    Have fun with the build...
    Apr 2013
    This is the part that has me most concerned, haha. We'll see what happens, I still have options and time. I just may go that route, who knows. =-)
    Apr 2013
    Ok, this seems like a killer deal. SLX 3x10 crankset, no BB. It says it only fits 68/73mm bottom bracket shells (I'm not sure what this means). Can I buy this crank and buy the BB92 pressfit and everything will work? I think that the 68/73 mm restriction is referring to normal bb, not press fit, but I need confirmation from the experts (you guys)
    Shimano SLX M660-10 OE Crankset > Components > Drivetrain > Cranksets | Jenson USA Online Bike Shop - Mobile
    Looks like a good deal. However, a few things to consider...
    1. Yes, 68/73 is the standard size, so will fit either a Shimano HTII external BB, or a BB92 press-fit, so no problems there.
    2. Doesn't matter that it doesn't come with BB as you'd need to buy the press-fit one anyway.
    3. Its 10 speed, but as we established earlier, this will work fine with your current 9sp setup, and it'll be all ready for when you upgrade the rest of the drivetrain to 10sp.
    4. M660 is the 'old' model SLX, which is most likely why its reduced. M670 is the latest model. Not much difference functionally, just cosmetics (do a search on SLX M670 to see what the latest ones look like), but it depends if you're more interested in price or having the latest model on show.
    5. As its the triple, the middle ring will be a 32T. If you're going to try running it as a double by replacing the big ring with a bash, that'll leave you with too small a 'big' ring. So, you'll most likely need to buy an additional M675 38T ring.
    Hope that helps...
    That SLX is the crank I got and it fit the pressfit BB on my Anthem. I'm running a single 32 ring with 11/36 cassette. This combo is perfect for my trails and I'm only on the dirt, no road riding.
    You posted "My main concern is my climbing gear" so that SLX combo should work even if you take off the big ring and add a bash. With the 32 I can hit 20mph before spinning out.
    Apr 2013
    Thanks for the feedback on the cranks guy!
    Next question. Fox CTD Remote or Monarch Rt3?
    Apr 2013
    Bump
    davidcarson48
    Guest
    If you are going to race, Monarch all the way. Trail ride? Either is fine.
    Apr 2013
    I wont be doing any racing, just trail riding. The monarch is cheaper, and I've read a lot of good reviews on it. I haven't seen much about the CTD. The alluring thing to me, coming from a hardtail is the ability to lock out the CTD. I suppose I can do that with that monarch as well, but I have to reach down to do it. That doesn't necessarily bother me if I'm not going to get my fingers caught in a bunch of moving parts. Anybody have thoughts on this?
    davidcarson48
    Guest
    The lockout lever on the Monarch is really easy to get to and i prefer the less cluttered look of no remote on the bars.
    Apr 2013
    It's like you're telling me exactly what I want to hear. Are you being paid by RockShox? Haha
    On a more serious note, I got a Rock Shox Reba fork. Has it been shown, or is it anyone's experience that it's best to run Fox front and back or RockShox front and back? Do the front and rear shocks of a certain brand tend to compliment each other for an overall better feel? Or is it really just user preference?
    davidcarson48
    Guest
    I'd say user preference. But the Anthem does ride more firmly with RS compared to Fox.
    Apr 2013
    Ok, so, my next question is about headsets. I realize I need a tapered headset. What I don't know is whether it takes an internal/zero stack headset or traditional. Will any of these work?
    FSA Gravity SX Tapered Headset | FSA | Brand | www.PricePoint.com
    FSA Gravity SX Pro Tapered Headset | FSA | Brand | www.PricePoint.com
    BlueSkyCycling.com - FSA Gravity DX Pro Headset
    Noob question here but for GXP bottom brackets I am upgrading from SRAM X5 crank to XX1 crank will I have to get a new GXP bottom bracket for my anthem x 29er?
    I realize that BB are not that pricey so any suggestions for a good value/performance GXP for the XX1?
    Apr 2013
    Bump.
    Can anybody shed any light on this?
    To clarify, I realize the Anthem uses 'overdrive' headset technology, but I am using a standard tapered RockShox Reba, so I don't need the overdrive stuff. I would like to purchase the headset online rather than at the bike shop to save money, but if I don't get any definite answer, I'll let the lbs sort it out. Thanks
    Jeff
    May contain nuts
    Std tapered fork & head tube = std tapered headset. (OD2 applies to original fork only)
    Not exactly. For standard taper fork you can still use the bottom part of the OD2 head set but you need a special top part for the headset. A standard tapered head set won't fit.
    If some one has a part number or actual size please post link.
    Apr 2013
    I don't have headset at all though because this is a build. So I can't use the bottom. I need an entire headset. I don't know if it needs a traditional, semi-integrated, or integrated headset. It seems like no one else here really knows either. Unless I hear back, I'll have the LBS handle it and I'll report back so the information is available to others.
    May contain nuts
    Yes, and Magneto is buying a complete headset for a std tapered fork, so he needs a std tapered headset. (Zero-stack or internal, not integrated BTW).
    Epic rider
    Reputation: rapsac's Avatar
    Sep 2004
    There are multiple threads on this. All alu Anthem X29 have the same head tube dimensions...
    So, a standard ZS (zero stack semi integrated) tapered headset would fit in order to run a standard tapered fork.
    Summarising:
    Have 1.25/1.5 ( "OD2" ) fork installed but want to run 1.125/1.5 ( "OD" ) fork?
    > change fork and change top part of headset assembly
    Have frame only and want to run normal tapered fork (1.125/1.5)?
    > buy fork and std ZS tapered headset
    Thats all there is to it....
    PS: owner of 2 alu AX29's: 1 OD and 1 OD2 (wife's bike)
    Verstuurd van mijn GT-I9505 met Tapatalk
    12 Anthem X29
    13 XTC 29
    07 Epic Marathon carbon
    04 Stumpjumper FSR Anniversary
    03 Stumpjumper FSR Pro
    00 Rockhopper Pro
    Apr 2013
    Ok,
    What I am getting from this and a few other threads that I have browsed is that I need an internal headset with 44 mm upper headtube diameter and 55 mm lower tube diameter. Can anyone confirm this?
    So, would this headset work? FSA Gravity SX Pro Tapered Headset | FSA | Brand | www.PricePoint.com
    rapsac,
    I have an FSA head set that fit perfectly in my anthem x29 OD frame that took standard tapered fork 1 1/8 - 1 1/2. That same head set does not fit my 2013 anthem x29 OD2. Bottom part of head set, yes. Top part has play as the outside diameter of the head set is slightly smaller than the frame. In other words, the FSA head set that fit the OD1 head tube does not fit the OD2 head tube.
    My OD2 frame is the advanced carbon but I don't think that matters. I have a third frame (OD2 anthem advanced)being shipped with the correct head set for a standard taper fork. When I get this frame I will put the calipers on it and post the difference.
    I have built up and swapped components on these anthem 29 frames - head sets, forks, stems and bottom brackets. I'm no expert but just relaying my experience.
    Epic rider
    Sep 2004
    Ok, I just gave my experience for the alu frame (clearly mentioned and now added twice for clarity).
    Anyway, agree that it is strange that for the carbon frame there is a difference. Would not have expected that! Thanks for clearing that up. Interested in measurements of the difference and of the outer diameter of the FSA upper cup that did not fit. Are there any markings on it to identify it as proprietary? And what Giant ships as upper cup now.
    12 Anthem X29
    13 XTC 29
    00 Rockhopper Pro
    Just pulled the top part of the headset of the OD and OD2 frames. OD frame is Aluxx and OD2 is Advanced, don't know if the carbon head tube is different diameter than aluminum but measured both on digital calipers. OD OD is 40.93mm and OD2 OD is 41.68mm. Both are FSA. I can post pic tomorrow as I can't upload photo now.
    The point is a top part of the OD headset for 1 1/8-1 1/2 will not fit OD2 head tube that takes 1 1/4-1 1/2. You need a special top part of the headset to run a standard taper fork in an OD2 frame.
    I have asked for a part number or link before and got no replies. Not even sure what to call this part, OD2 reducer headset? I'm sure Giant sells it for more than a complete headset.
    Here are the pics, top parts of head sets both FSA. The outside diameter of the head set measured with digital caliper, smaller o.d. is from OD1 head set and the larger o.d. is OD2 head set. This is why you need a special top piece if you want to run a standard taper fork in an OD2 frame.
    Epic rider
    Sep 2004
    Hi BacDoc,
    It looks like you measured the outside diameter of the bearing itself. Do you have the measurements of the cups that are pressed into the frames? (measurable when removed from the frame) Or even better, the inner diameter of the steerer tube of the frames with the bearing cups removed.
    12 Anthem X29
    13 XTC 29
    00 Rockhopper Pro
    Quote Originally Posted by rapsac View Post
    Hi BacDoc,
    You may have a valid point there, but it was easy to pull bearings and measure them.
    My new advanced frame might be here today or monday and I will measure that since it will be easier to pop the complete head set with just the frame.
  1. Building a Chameleon - Input welcomed
    By BigJoeJack in forum Santa Cruz
    Last Post: 04-02-2015, 10:27 PM
  2. Building a nickel would like some input
    By DAnREal in forum Santa Cruz
    Last Post: 09-05-2012, 02:17 PM
  3. 2011 Anthem X 29 with 120mm fork input please
    By dimitrin in forum All Mountain
    Last Post: 10-18-2011, 10:05 PM
  4. Replies: 1
    Last Post: 10-16-2011, 06:55 PM
  5. Size input for new Anthem X 29
    By DanielM3 in forum Giant
    Last Post: 01-11-2011, 08:40 AM
