Results 1 to 7 of 7
    Broken bolt form upper link giant reing 2 2011
    Hi
    I need new bolt form upper link giant reing 2 2011
    Broken bolt form upper link giant reing 2 2011-giant-reign-2011-bolt-link.jpg
    How to remove this bolt- it have broken hex socket ?
    Need shop in Europe :-)
    Sep 2012
    try tapping a torx bit into the hex head, it may have enough grip to get it out. note hammering it in may be damage the frame pivot so take care.
    Reputation: mizzaboom's Avatar
    Jun 2010
    Let me see if we are on the same page here -- is the bolt broken or is the end of a hex wrench broken off and stuck in there? Or both? Also, aren't all of those torx heads on those pivot bolts?
    I've never had to remove a pivot bolt like that...but in my days as a ski tech I removed many a screw by carefully Dremel-ing a notch in the head and removing it with a flathead screwdriver.
    All good things in all good time
    Broken bolt form upper link giant reing 2 2011-img_7697.jpgit is end of a hex wrench broken :-)
    Jun 2010
    It is hard to tell in the picture what is going on and I think we have a communication barrier here. It looks like it is just stripped. Try carefully Dremel-ing a slot in the bolt that is big enough to fit a medium sized flat head screwdriver. That should do the trick.
    Mar 2011
    You can also try a damaged screw remover, it will drill out the bolt a small amount and then it threads itself into the drilled out part in reverse causing the screw to come out. Not sure where you'd get one in Europe.
    As posted previously a dremel tool with a small cutoff disk will work aswell, just cut a small slot in the screw and remove it with a flat head screwdriver.
    thanks
    Sorry for my english ( it so bad)
    I will try tapping a torx
    I have contact polish giant for new bolt, but no results
  1. Santa Cruz TRc broken bolt lower link
    By ban in forum Santa Cruz
    Last Post: 08-10-2012, 11:07 AM
  2. A Hole in the Ground (and a broken link, a sheared bolt)
    By ElHombre in forum California - Norcal
    Last Post: 07-12-2012, 09:01 PM
  3. Stripped axle bolt upper link
    By mcandy in forum Santa Cruz
    Last Post: 04-06-2012, 08:51 PM
  4. Trance X broken upper shock mount bolt
    By 661lee in forum Giant
    Last Post: 03-15-2012, 04:14 PM
  5. Giant reign 1 2011 master link vs Kona cadabra 2011 magic link
    By Giwrgoscharala in forum All Mountain
    Last Post: 02-07-2012, 02:39 AM
