Results 1 to 8 of 8
Thread: ax29 creaking
    Jun 2012
    ax29 creaking
    has anyone located the source for the linkage creak? is there one specific bearing that goes bad or do they all need to be replaced?
    WillWorkForTrail
    Jun 2012
    My AX29 was creaking a bit after a few months, I checked the torque on the cranks, to make sure that wasn't it, then carried it back to my lbs. They verified torque for all the linkages, and checked that, put a tiny tiny bit of tri-flow on each one, and it hasn't made a sound since.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Quote Originally Posted by txfly View Post
    What year is it? How old? How many miles/hours on it? Lots of variables here. Creaks can come from a hundred different places and people often assume it's from the linkages. Most often, believe it or not, it's from the seatpost.
    I'm a mountain bike guide in southwest Utah
    Feb 2007
    Quite a it of missing information for us to give an accurate answer.
    Jun 2012
    I had a truckload of creaking and sourced it to the seat flexing and mainly the seat post which was as dry as a nuns nasty!
    Bit of grease and now all good.
    lurking no more
    Reputation: nocnypatrol.org's Avatar
    check dereaulier hanger - it was cracking each pedal stroke i made, took me about a week to discover that the hanger was the source, a bit of grease between frame and hanger and now silence
    Reputation: Mark16q's Avatar
    Same here. All quiet now.
    Quote Originally Posted by nocnypatrol.org View Post
    '16 Scott Genius 700 Premium
    '14 Giant Anthem Advanced 1 27.5"
    Cervelo R3sl
    Seven Alta
    Curtlo h/t
    Hi,
    I sourced a creak from seatpost clamp.Not from post,but actually from clamp.I took it off frame and greased where it sits on frame.No creaks now!
    Thanx,
    Max
