    Any Trance model without integrated headset?
    Hi,
    I am looking forward to buying a Trance frame and I would like to use my talas with 1.5 tube. I have now that fork in a 44mm width head tube (a semi integrated head tube of a Reign 2007) using a Nukeproof Warhead 44EEOS headset.
    The question is: all the yearly Trance models use the integrated headset? Was there a year were they use the 44mm head tube?
    Thank youˇˇ
    MTB B'dos
    Reputation: LyNx's Avatar
    Your research has proved flawed, they never used an integrated HT, like the Reign they use a 44 internal HT which can accept the external 44 cup to let you use a tapered steerer fork.
    Trances use a zero stack or semi intergrated head set. Like Lynx said you can use an external 44mm 1.5 bottom cup for your tapered fork. Check out the crane creek website.
    Thank you Lynx, I was in a big bessˇˇ
