Results 1 to 3 of 3
    Anthem X shock size
    I am looking to move from my 07 Trance frame to the new 09 Anthem X frame. Only problem is that the Anthem X0 frames are out of stock until 2010. My lbs offered to sell a stripped down X2 frame (for a little bit less $, but not much) which I am considering but it comes with the RP2. I have a RP23 on my Trance (6.5 x 1.5), the question is will this fit on the new Anthem frame? Thanks
    johno
    Anthen X shock size
    Just today I've done exactly what you are considering.
    Giant would not warrant my cracked 07 Trance Advanced Frame. Instead they offered to sell me an Anthem X Ltd frame for wholesale - less shock as the Trance RP23 fitted straight on. However the bottom shock mount spacing on the Anthem X is narrower, so you will need specific spacers and shock retainer bolt. Hope this helps
    The shock on a anthem X is 6.5x1.5 so it should fit fine.
