Results 1 to 3 of 3
    Mar 2006
    Anthem x 29er crank question
    I am looking to buy a set of Shimano m780 cranks for my Giant. The problem is I do not know if off the shelf cranks and BB will work or if I need something else. anyone switched made this switch before that can give me some advice? thanks
    The crank itself will work fine. Most of the cranks come with the standard threaded bottom bracket. The anthem uses a press fit. Depending on what you are replacing ( if it's shimano also) and your current one is in good shape you can reuse it.
    Mar 2006
    JasonL thank you. I have the stock Sram set on now, so will look at getting a press fit BB along with the crank set. thanks for the help!
  1. question about bracket on my anthem 29er...q
    By 56cbr600rr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-19-2012, 03:15 PM
  2. Anthem 29er 2x10 question
    By Pock in forum Giant
    Last Post: 12-04-2011, 12:24 AM
  3. Question for Anthem X 29er owners
    By Bulldozer27 in forum Giant
    Last Post: 09-23-2011, 08:08 PM
  4. Anthem X 29er - sizing question
    By Jisch in forum Giant
    Last Post: 07-16-2011, 06:05 PM
  5. Sizing Question Niner vs. Giant Anthem X 29er
    By wesmeyer11 in forum 29er Bikes
    Last Post: 01-07-2011, 12:06 AM
