Results 1 to 3 of 3
    Anthem X 29er 2 (2012) - Hubs question
    Hi,
    N00b question , i would like to build my own wheelset, based on HOPE pro2 evo hubs, i will change my fork legs so they will match the 15mm Axle.
    the usage is XC only for 185lbs rider.
    can you confirm that the following hubs are suitable :
    front: Hope Pro 2 Evo Front Hub 15mm Axle 32h
    Rear: Hope Pro2 Evo Rear Disc Hub 135mm 32H Black , or should i use the 142mm X 12 ?
    Thanks for your support
    Mar 2011
    Those hubs should work without a problem. Hope hubs can also be converted from 9mm to 15mm to 20mm on the front with simple conversion kits. As for the rear hub standard size is the 135mm hub with either 9mm QR or 10mm bolt on working on most bikes equipped with QR on the rear.
    Quote Originally Posted by sascwatch View Post
  1. 2012 Giant Anthem 29er 2?
    By Trek13 in forum Giant
    Last Post: 06-24-2013, 06:06 PM
  2. My New 2012 Anthem x 29er 1
    By benparker79 in forum Giant
    Last Post: 04-25-2012, 02:05 PM
  3. 2012 Anthem X 29er
    By nikwashere in forum Giant
    Last Post: 04-17-2012, 03:41 AM
  4. Reba RL on 2012 Anthem 2 question
    By shamanrawb in forum 29er Components
    Last Post: 03-10-2012, 05:46 PM
  5. 2012 Anthem X 29er Tires (USA)
    By wpodriver in forum Giant
    Last Post: 09-19-2011, 05:25 PM
