Results 1 to 6 of 6
    Nov 2006
    Anthem x 29 with long travel fork
    Considering installing a 140-150mm on my xc bike to give me some bigger bump capacity and a tad slacker head tube angle. Since the bike has a relatively low bb height and I'm running the saddle all the way back.
    I'm not ready to jettison my 29er setup but am feeling the ill effects of 70 deg head angle and paltry 100mm of travel
    Any things to consider ?
    Reputation: jkirkpatri's Avatar
    Take the money for a new fork and put it towards a Trance and sell your Anthem to help with the purchase. No point in making the Anthem onto something it's not especially when it sounds as if the Trance will suit your needs better.
    Nov 2006
    I love the way the bike rides and perhaps my need for a slacker & longer setup just means a second bike. No one bike does it all.
    You could get a 120 mm fork instead and if it's too much, try it reduced it to 110 mm. I wouldn't necessarily add a 120 mm fork for the travel increase alone, but...I would do it with the idea of upgrading my fork, and benefitting from the slight increase in bb height. If you want longer travel, the other post above makes sense about moving over to a Trance. Find somebody, or a shop with a Trance and try to arrange to go riding you and another person and switch back and forth. You may find the Trance is more what you want, or maybe not.
    bacon! bacon! bacon!
    Keep the Anthem... get a Reign. Problem solved.
    Dec 2009
    Quote Originally Posted by jhbeeton View Post
    I'm running a 120 fork on mine at 69.3 degrees . You can add a works or angleset hedaset to slack it out more. I'd sell the bike if i was tempted to run any longer fork.
  1. Let's see those long travel 29ers! 140mm+ fork only.
    By BloodyRoots in forum 29er Bikes
    Last Post: 04-08-2017, 04:55 AM
  2. 2013 Fuel EX 8 long travel fork.
    By dea1276 in forum Shocks and Suspension
    Last Post: 06-13-2013, 06:52 PM
  3. Rip 9 + extra long travel fork question...
    By StayGolden2 in forum Niner Bikes
    Last Post: 07-21-2011, 01:14 PM
  4. Long(ish)-travel 20mm fork on a Jekyll?
    By bassteban in forum Cannondale
    Last Post: 01-28-2011, 09:34 PM
  5. Anthem fork travel advice...
    By GS833 in forum Giant
    Last Post: 01-26-2011, 04:33 PM
