Results 1 to 11 of 11
    WillWorkForTrail
    Jun 2012
    Anthem BB compatibility
    Having switched my 2013 Anthem over to 1x10 using a Wolf Tooth ring, I feel that 1x is the way of the future. Sadly, I also think that the 36 tooth ring may be to big, but that's the smallest ring I can put on a 120 BCD crank. So, I can look at other SRAM BB30 cranks, or I can look into ...other options. Except BB30 is pretty much only SRAM stuff as far as I can see. What do I need to do to use a 104 Shimano crank on the Anthem frame? Basically, I'm looking for options.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    I don't know where you got BB 30 from. The Anthem doesn't use that standard.
    I'm a mountain bike guide in southwest Utah
    WillWorkForTrail
    Jun 2012
    Maybe I'm asking the wrong question. I know a lot more about riding bikes than what standards are called. It uses a press fit BB, PF30 I think - at least mine that came with X7 cranks does.Which means any crank compatible with BB30 will work with that BB. I think. See, that's where I could be wrong. But when I look for that, I get only SRAM stuff.
    So maybe...what do I have to do to run a 104 BCD crankset on my '13 AX2 that came with SRAM cranks?
    Your Anthem has a GPX press fit BB. Not a BB30. Your SRAM cranks are GPX as well. BB30 will not fit.
    If you want to run a Shimano BB71 press fit BB. You could also use a Shimano BB91 which is the same but XTR level.
    You can get down to 30t on 104bcd
    Quote Originally Posted by Cotharyus View Post
    Praxis Works | Conversion Kit
    OG Ripley v2
    Carver 420 TI
    WillWorkForTrail
    Jun 2012
    Thanks for clearing up the BB issue. I was going by what a shop mechanic said. I haven't known much about bottom brackets since square tapers started coming in sealed cartridges. Upon further examination, you can see "GXP" on one of the seals visible in the gap between the crank arm and the frame. That solves my problem entirely.
    You can get the sram X0 DH and XX1 cranks in gxp. I have the former with 104BCD wide narrow teeth on single speed, and the latter on 1X10 on another bike (but bb30).
    Out of interest, I nearly went for an anthem x1 29 2013 in the sales and would have put X01 on it to bring it down to a decent weight, would i need a GXP version rather than bb30?
    Your Best Friend
    Yes. Everyone needs to forget BB30 when talking about anything Giant.
    Right. Good to know. What put me off was the steerer being odd as well - limited stems.
  1. Replies: 16
    Last Post: 10-09-2013, 07:40 AM
  2. Replies: 4
    Last Post: 01-31-2013, 06:54 PM
  3. Anthem X29 and Talas compatibility?
    By MAX LLOYD in forum Giant
    Last Post: 11-24-2011, 10:15 AM
  4. Crankset Compatibility with Giant Anthem 29er
    By IndianaXC in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-28-2011, 06:33 PM
  5. Replies: 2
    Last Post: 05-11-2011, 11:32 PM
