Results 1 to 3 of 3
    Anthem 29er 260lb rider
    I have a reign with a fox DHX. I am at or a little above the max pressure for the shock and I would like it even firmer but can't put the pressure up more. I don't know much about the leverage pressure ratios. I haven't had this problem with other bikes. Would the anthem be the same?
    Sent from my DROID RAZR using Tapatalk
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I am the same weight and run less than 250psi on an Anthem x 29er, so . . . . .
  1. Replies: 15
    Last Post: 01-18-2012, 12:45 PM
  2. My new Anthem 29er
    By Pock in forum 29er Bikes
    Last Post: 01-18-2012, 12:11 PM
  3. Is 29er with couplers realistic for air travel?
    By TwoNin9r in forum 29er Bikes
    Last Post: 01-17-2012, 01:40 PM
  4. Replies: 0
    Last Post: 01-13-2012, 12:12 PM
  5. Help select a 29er HT....$2500 or less
    By sbermhb in forum 29er Bikes
    Last Post: 01-11-2012, 05:42 PM
