Results 1 to 6 of 6
    Anthem 142 axle help
    I purchased a used anthem 27.5 frame that did not come with a rear through axle. The thread pitch on the giant frame insert is more coarse than the DT 142x12 axle in my Specalized.
    Does the Giant use a shamino axle without the shamino insert or is it Giant specific? Please post a link to an axle that will work with my new Anthem. I can't wait to get it built. Thanks!
    Quote Originally Posted by jds2835 View Post
    Just went through this with my anthem 27.5 frame.
    The website said it came with a Dt Swiss 142 axle, but my frame only had a qr skewer. Tried to install a dt Swiss axle and the thread pitch did not match.
    Contacted giant and they said website is wrong and aluminum frames do not come with 142 axles. My LBS got giant to send an axle and it was clearly made by dt Swiss but with different threads. Annoying proprietary threads from Giant.
    Have no idea if a shimano axle would work. It all depends on matching the threads on the frame. Your best bet might be to have a giant dealer order an axle.
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    Surprised me too. Hoping to source one through a local dealer. Anyone need a DT Swiss 12x142 fine thread thru-axle...let me know.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    Apr 2014
    Same thing happened to me when I bought my Giant Trance frame-set. My LBS called Giant, and it seems to be a common problem. They sent me another axle that had the correct threads, that would work.
    Reputation: madsedan's Avatar
    Aug 2010
    I have the conversion parts but haven't pulled the trigger on a 12x142 skewer for this reason, I read some people saying its proprietary but my LBS says any DT Swiss 12x142 skewer should work, crazy.
    I think its just because my dealer hasn't ordered one yet possibly.
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    The regular DT Swiss is the wrong thread pattern without a doubt.
    2015 Kona JTS
  1. Sanction thru axel?
    By pinoymtb in forum GT
    Last Post: 12-25-2012, 09:45 AM
  2. DT hub thru axel quest
    By andyjensen in forum Wheels and Tires
    Last Post: 06-08-2012, 03:58 PM
  3. RS Psylo 20mm Thru axel and Sram 15mm thru axel
    By Haystack Calhoun in forum Shocks and Suspension
    Last Post: 02-16-2012, 09:10 PM
  4. Taper HT and Thru Axel..Is it really necessary?
    By snellvilleGAbiker in forum General Discussion
    Last Post: 08-10-2011, 12:11 PM
  5. 20mm axel to 9mm QR
    By jrsbike in forum Wheels and Tires
    Last Post: 03-15-2011, 06:35 PM
