Results 1 to 6 of 6
    Reputation: Clintox50's Avatar
    Feb 2005
    Anthem 0 rear tire clearance
    I've got an '07 Anthem 0 (not the X) and was considering getting some WTB Wolverines. Does anyone know if the Wolverine 2.2 will fit in the rear? I've had a Kenda Nevegal 2.1 on with no problems.
    Another question. Would anyone forsee a problem with the 2.2's on the Mavic Crossmax SL's? Mavic doesn't recommend a tire larger than 2.1. I would be mounting them tubeless with Stan's as well, without strips which is how I currently have 1.95 WTB Exiwolf's hooked up.
    Husband - Dad - Bike Racer - Race Director
    Clipped In Races
    I have an '06 Anthem. I'm running 2.35" small block 8's on mine. They fit, though there isn't a lot of extra room in the frame. The tires never rub the frame, but because there's not much clearance leaves get stuck in between the tire and rear triangle a good bit. Not a big deal, it's just annoying when you get one in there that won't come out on it's own and it makes a bunch of noise for a while.
    Feb 2005
    Just in case anyone was wondering. The 2.2 WTB Wolverine's fit fine. :-)
    Clipped In Races
    I run bontrager 2.2's front and rear on an 07 anthem O with no problems whatsoever.
    Will Rocket Ron 2.4's or WTB Mutano 2.4's fit?
    Hi,
    I also have a 07 Anthem 1.
    I want to Try those Maxxis Semi-Slick Highrollers ... but they only come in a 2.35 size...
    Any input would be greatly appreciated, thanks
