Results 1 to 2 of 2
    No Brakes
    Reputation: No Brakes's Avatar
    New question here. AC Fork Choices...
    Hello everyone,
    Kinda new to posting on this board but I've been lurking...heheheh.
    Anyhow, given the following choices for a fork, what would be your opinion and why? Personally, I'm leaning toward the 2004 Marz Z1 Drop Off 1 but I would like to hear other's opinion.
    (BTW, this will be my first "trail/freeride" bike...currently, I'm riding a 2001 NRS w/Marz MX Pro in the front and the stock SID in the back...and that's about the only stock item on the bike. I weigh about 175 sans gear or 185 with.)
    Thanks very much in advance!
    2004 Marz Z1 FR
    Pros: Stiff, ETA, external air preload, external rebound, accept tires up to 2.7"
    Cons: Heavy ~5.82 lbs, most expensive of all because of the damping system
    Cons: Heavy ~5.32 lbs
    2004 Marz Z1 Drop Off 2
    Pros: Stiff, external air preload, cheap compare to the others (~$315)
    Cons: Heavy ~5.24 lbs, No ETA, internal rebound
    2004 Fox Vanilla 125 R
    Pros: Cheaper than others...PUSH-able, ~4.09 lbs
    Cons: No lockout
    2004 Fox Vanilla 125 RL
    Pros: Lock out...PUSH-able, ~4.11 lbs
    Cons: Expensive
    2003 Marz Z1 FR
    Pros: Stiff, ETA, external air preload, external rebound, on sale at Supergo for <$350
    Cons: Heavy (can't find info on the apprx weight)
    BIGNATE
    don't forget the shermans
    My AC1 came with the sherman firefly, which is about as light a the fox forks but performs like the Z1 (actually feels quite a bit better than the Z1's that I've ridden). The firefly complements the AC frame very nicely and I would highly recommend looking into it before making a final decision. It's a little pricey, as is the fox, but well worth it.
    BIGNATE
  1. Replies: 5
    Last Post: 04-28-2004, 03:47 PM
  2. Replies: 5
    Last Post: 04-14-2004, 08:19 AM
  3. Cannondale Lefty Max+ compared to TALAS :my $.02
    By dawgcatching in forum Shocks and Suspension
    Last Post: 04-13-2004, 10:39 PM
  4. rigid fork question: Alu, steel, carbon...
    By jh_on_the_cape in forum Singlespeed
    Last Post: 03-24-2004, 05:18 PM
  5. Replace Manatou Black fork with?
    By Thumbie in forum General Discussion
    Last Post: 02-16-2004, 10:30 AM
