Results 1 to 9 of 9
Thread: 8 inch reign
    Too Kool for Skool
    Reputation: theg1ant's Avatar
    8 inch reign
    Could u put an 8" rotor on the back of an 05 reign? I am looking at a cheap increase of stopping power and i am definatly putting an 8" er on the front and was wondering if you could do the same to the back (with an adapter of course) Would this void the warrenty and possibly damage the frame?
    Quote Originally Posted by coma13
    it's short but it's pretty.... just like a guatemalan hooker...
    New question here.
    Quote Originally Posted by theg1ant
    Could u put an 8" rotor on the back of an 05 reign?.....
    You surely won't damage the frame, but I wonder why do you need so much stopping power at the rear?
    I live to bike
    Reputation: Jwiffle's Avatar
    Yes, you can put an 8 inch rotor in the rear. I have an 8 inch XT brake on my '05 Reign. No problems.
    Too Kool for Skool
    Thanks all. i want an 8" front and rear b/c I cant afford new brakes and need a cheap way to improove stopping power over the soles
    Good job!
    IMHO upgrading only the front brake to an 8in, will be sufficient...I run 7in Juicies front and rear and 7in is too much for me for the rear end, I'll switch to 160mm...but you know your riding best.Good luck with the upgrade!
    Too Kool for Skool
    Thanks Everyone for your help. 7in in the rear might be too much 4 u because u have juicys and both pads move on those. Soles only have one moving pad and act like a mid range mech with fluid inside.
    Reputation: Ro.nin's Avatar
    Jun 2005
    Pm
    Newone - check your PM.
    Quote Originally Posted by Khemical
    wizzler is a must. although then it consumes all your waking and sleeping thoughts until you can return.
    In exile
    Reputation: loco-gringo's Avatar
    I'm cool with 7" Juicys, but I will put an 8" up front when I need a rotor. I agree that 7" in the back is good though.
    8" up front will make a HUGE difference.
    Too Kool for Skool
    alright thanks. maby ill just get a 8" up front and if i need more stopping power then ill think about a bigger back.but b4 i spend $$ on that i need to get new shoes
