Results 1 to 2 of 2
    New question here. 5th Element setup on AC2
    Hi there,
    I'd like some input on your preferred settings for the 5th Element coil - I'm 160 lbs and have a 400 lb spring. Here are the initial settings Progressive suggested:
    Sag: 1/2"
    Air volume: 3 returns out from all the way in
    Air pressure: 150 psi
    Beginning stroke: 1.5 returns out
    Ending stroke: 1 return out
    Rebound: 2 returns out
    These work well to cancel bob, but I'm looking for a little more compliance in the ride (on small or braking bumps for example). Anyone with a similar setup have any suggestions?
    Anyone with a dialed-in setup on a Swinger have any suggestions??
  1. Replies: 2
    Last Post: 05-05-2004, 04:08 PM
  2. Negative gulp air pressure in 5th Element Air
    By MCF in forum Shocks and Suspension
    Last Post: 05-03-2004, 09:38 AM
  3. older Superlights with a Fox ProPedal, 5th Element, or Man SPV. Anyone?
    By mergs in forum Lights DIY - Do It Yourself
    Last Post: 03-31-2004, 10:17 AM
  4. 5th element setup for '04 AS-X
    By fr33rdr in forum Yeti
    Last Post: 03-12-2004, 04:30 PM
