Results 1 to 27 of 27
    Apr 2013
    2013 giant reign 2, with coil shock
    hello, just wondering if you can put a coil shock on a 13 reign 2 to make it a bit beefier in the back for more free ride type stuff. if it is possible, how much will it affect pedaling as i still want to use it as an all mtn bike as well. what type of shock would it need and what size?
    would appreciate any help thanks
    Apr 2013
    anybody?
    literally any help would be appreciated
    Quiet Professional
    Reputation: chef7734's Avatar
    Re: 2013 giant reign 2, with coil shock
    You can. You could either put the stock 7.875 x 2.0 or put a 7.875 x2.25 and increase the travel to 6.7"
    Sent from my Transformer TF101 using Xparent BlueTapatalk 2
    Apr 2013
    how much will the 6.7" affect pedalling? would it be better than 6" for a fr oriented all mtn bike?
    Quiet Professional
    It will be the same but give you an extra .7" travel. Be closer to a reign x. The coil shock will make it more linear than an air shock.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Keep in mind this will void the lifetime frame warranty you have (had).
    I'm a mountain bike guide in southwest Utah
    Apr 2013
    is it still easy to pedal uphill or is there to much of a bobbing motion?
    Quiet Professional
    It will feel the same as the 2.0.
    Apr 2013
    is it harder than an air shock for xc riding?
    Quiet Professional
    If set up right it will feel similar to an air shock.
    bacon! bacon! bacon!
    Not sure what air can you have on it, but I switched awhile ago to a 3.875x2.25 Van-R coil on the rear of my '10 Reign. It is better in all aspects except that it will add quite a bit of weight to your build. I also like the fact that there's no "fiddling" involved.
    Apr 2013
    nice ride there. whats the toughest it can handle? and would it be worth putting on a fox 36 talas fork for the adjustible 120-160mm? and how hard is it to do a cross country loop on it?
    Quiet Professional
    Most people say stick with the float over the talas. The 36 stiffens it up quite a bit over the 32. If you do go with a 36 or 34 you could go up to 160 vs the 150 to match the 2.25 on the rear. Check out the Giant Reign Modifications (Not Reign X) thread.
    Apr 2013
    is the float adjustable?
    Your Best Friend
    Adjustable in what way? Travel? No.
    Quote Originally Posted by bigred543 View Post
    Toughest it can handle? I dunno. Tougher than I'm willing to try.
    Personally I'd go for a Revelation instead of a Fox 36 - the one I tried on my Reign was *way* stiffer than the Fox 32 that I have on it at this point.
    How hard is a XC loop? I dunno... that pic that I posted was from a 3-day trip of big high country rides and I survived. So take that FWIW.
    Apr 2013
    was there any bobbing on long climbs?
    Quiet Professional
    If it is set up correctly it will not bob.
    Apr 2013
    is it actually worth switching to coil? and how much does a fox van r usually cost? australian dollars prefferred
    Quiet Professional
    I ride air now. Some people prefer air some prefer coil. An air can handle just as much as a coil if you have the right ones. They have improved so much when it comes to air cans that some dh bikes have them. You need to ride a coil and ride an air to see which you prefer.
    It was for me. Better performance, less fiddling, and less $$ than getting a "good" air can. I spent $90(USD) on a used Van-R and upgraded it with a Ti coil spring in the appropriate weight.
    Apr 2013
    how hard is it to switch between air and coil? say i want to go for an xc day can i switch back to air easily or does it need to be fitted correctly and vice versa
    Quiet Professional
    Why would you keep switching back and forth? Just pick air or coil and run it all the time.
    I have a 2011 Faith 0 and switched out the Vivid Coil with a Vivid Air and prefer the Vivid Air. Although I could have switched out to a heavier coil I decided to go with Vivid Air.
    The Vivid Air pedals better and is much more adjustable, air pressure aside. If you're the right weight coil might be the way to go but if you're in between weights then air is better.
    Having an air shock that's adjustable to your weight is such a help on jumps. It's good not to throw out your back because you can setup the correct pressure.
    Apr 2013
    Quote Originally Posted by Silentfoe View Post
    if i put a coil on then decide i dont like it, then switch back to air, will it still void the warranty. Also will putting a fox 36 tals or 34 float void warranty?
    Quiet Professional
    If you put a 7.875 x 2.0 coil it will not void the warranty and if you dont go over 160 on the front you are fine. Also if you kept the old shocks there is no way to tell that you had them on. If you have issues with the frame just reinstall the old shock and fork before taking it to shop.
    Apr 2013
    thanks, that should be all my questions i think
    appreciate the help
  1. 2013 Giant Reign 26b set-up
    By gfowkes in forum All Mountain
    Last Post: 08-30-2013, 01:47 PM
  2. 2013 Giant Reign 1 vs 2013 Giant Trance x 1
    By PureAwesome in forum General Discussion
    Last Post: 12-26-2012, 10:03 PM
  3. 2013 giant reign
    By jbone ll in forum All Mountain
    Last Post: 06-08-2012, 08:18 PM
  4. Coil or Air shock on a '08 Reign X0
    By FlippinSweet in forum Giant
    Last Post: 03-02-2011, 10:31 AM
  5. 2010 Giant Reign with a coil rear shock
    By bmxconvert in forum Giant
    Last Post: 02-22-2011, 08:56 AM
