Results 1 to 16 of 16
    Jan 2011
    2012 Trance x4 chain guide
    I hardly ever use my third ring so I am going to put a bbg bashguard but I figure I need a chain guide to use the same chain, reduce the chain slap and miss shifts. I have a couple of questions
    1) can I use this type of product? Blackspire Stinger Chain Tensioner - Blue 2012
    Blackspire Stinger Chain Tensioner - Blue 2012 | Buy Online | ChainReactionCycles.com
    or
    2) Accessoires I think it does double takes away the chain slap and guides the chain.
    or any recomendations?
    Reputation: 'size's Avatar
    you don't need a chain guide/tensioner necessarily. first re-size the chain to the correct length for the smaller 'big' chainring you'll be running and see how it goes. since you're keeping the front mech you probably won't need anything.
    however if you do decide to get something, either of those options will work.
    Jan 2011
    Okay thank you.
    May contain nuts
    Reputation: Haggis's Avatar
    Can't use Stinger on press-fit BB. Bionican guide should work ok, if chainstay isn't too low...
    Quote Originally Posted by Haggis View Post
    thanks for that correction - i keep forgetting the newer giants use a press fit bb.
    Jan 2011
    okay thanks. X4 all stock so should be fine right??? or should I just shorten the chain a little. and leave my chainstay protector??
    Quote Originally Posted by trdspectacoma View Post
    just re-size the chain correctly and run it. i bet it will be fine.
    Jan 2011
    Feb 2012
    my setup on my trance i just took some links out
    " width="549">
    About the chain, how long is long enough? I removed the biggest chainring recently
    Any standard?
    Feb 2012
    i took out about 4 links and used a SRAM quicklink
    Quote Originally Posted by cscsw View Post
    Any standard?
    I think its something like when in lowest gear, the derailleur should hand at right angle to the floor.
    can someone give more info on that please as i need to remove some links myself.
    Any standard?
    run the chain around the largest chainring and largest cog without running the chain through the mech and add two links to that length is the rule of thumb. mech should be at roughly a 45* angle when in the big-big combo and run through the mech.
    Mar 2012
    I ear about a chaing guide that is put on the link (mestro system).....
    Feb 2012
    Is a bash guard necessary if I want to run a 2x9 setup?
    Jan 2011
    really quick update what size bashring do I need i know it is 104 but how many teeth
    ie 32 or 44
