Results 1 to 2 of 2
    2012 Reign Questions:
    Giants website is notoriously devoid of information, so I'd figure I'd hit you guys up for some information.
    For reference, I'm looking at getting a used Reign.
    1. Is the bottom bracket press-fit (I've heard rumors?), or just normal threaded?
    2. Whats the deal with the Giant Overdrive head-tubes? What are the size of the head tube, and what headset will I need to put a standard straight steerer in? I'd perfer a cane creek!
    3. I know some people "convert" these to a Reign X by added a longer stroke shock, is this still possible? I don't anticipate ever doing it, but my younger brother who'll most likely be using the bike in the future might want to.
    Thanks dudes
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    Quote Originally Posted by arkon11 View Post
    Pressed in - BB91/92
    44 top
    56 bottom
    there are a few Headset options out there.
    Reign uses a 7.875 x 2 shock
    Reign x uses a 7.875 x 2.25 shock
    you can use a longer stroke shock on the Reign, but if you use a front derailleur, you need to check for clearance under bottom out (make sure it doesn't make contact with swingarm)
