Results 1 to 3 of 3
    Reputation: dynamic161's Avatar
    Jan 2011
    2012 Anthem X 29 Headset for Overdrive 2
    I just ordered a 2012 Anthem X 29 frameset with the Overdrive 2 Headtube/Bearings. Does anyone know the upper head tube inside diameter? I would like to run a standard 1-1/8" to 1-1/2" tapered fork. Or, if anyone knows which headset/bearing I would need I could use that info as well. I would like to order the correct pieces so that I have them in time for the build.
    Many Thanks!
    '12 Anthem X29 Custom Build
    '11 Masi Evolution Custom Build
    Epic rider
    Reputation: rapsac's Avatar
    Sep 2004
    AFAIK the standard separate frame comes with 'normal' overdrive headset = std tapered.
    Frames are all equal, only top part of headset differs between OD and OD2.
    A Chris King inset 2 will fit nicely, use that as a size reference.
    Verstuurd van mijn GT-I9100 met Tapatalk
    12 Anthem X29
    13 XTC 29
    07 Epic Marathon carbon
    04 Stumpjumper FSR Anniversary
    03 Stumpjumper FSR Pro
    00 Rockhopper Pro
    May 2010
    are there any aftermarket overdrive 2 (1-1/4" to 1-1/2") headsets now available?
