I completely agree with abeckstead. The 2011 X2 has a much better compliment of equipment on it than the X3 (2012). (RP23 shock, SLX Shifters instead of SRAM X5, XT rear derailleur instead of the SRAM X7, P Series wheels instead of S Series, etc).
I'm not an expert on the frame geometry by any means but I can't imagine there is much difference between the 2011 and 2012...although I'm sure someone will chime in if there is.
I recently bought the 2011 X2 and absolutely love it!!!
I have a 2011 Trance X2 and would recommend changing the brakes and the fork. However I ended up changing the rear wheel involuntarily after tacoing it.
The stock fork isn't bad but I thought the fork on my old 29er hardtail (2010 XTC 29er1) felt better so I changed it out for a Fox 140 FiT,I got a great deal on the fork and only paid $275 on ebay for it. At my weight level (190 lbs) I was blowing through the stock fork too easily on jumps. The Fit 140 is a much better fork and is both smoother and more versatile than the Stock 125 RL. In addition to being a better fork the Fit 140 also slacks out the bike quite nicely and makes jumps that much easier.
As far as the brakes are concerned I went with Avid's Code R's,they have much better stopping power than the Elixir 3's and allow you to push the bike harder.
I also changed out the stem and changed the stock saddle for a leather one. I also went a cheap generic seatpost so I could cut it.
After all my changes I turned my Trance into a very nice jumper.
Taking it out this Sunday. Do you recommend leaving the bike stock or some parts I should change? I'm definitely getting the hydraulic seatpost next.
If you got money to burn on upgrades I'm sure ya could find lots to mess with. I personally would just ride the thing, it's a badass bike as-is IMO. I'm 185-190 depending on the day and my fork is doing fine for me. Mine has Elixir 5's and if anything they work too GOOD. Fawker put me on my ass last weekend... too much front brake.
I'd just go ride it and see what you think from there. If you need to do upgrades you'll figure that out in due time.
The only problem that I had was after about 8 - 10 rides I had a horrible harmonic sound happening when I used the rear brake. Did some checking on MTBR and found that this did sometimes happen with the Elixer 3's (and maybe others). I changed the rotor out for a Shimano XT rotor and that took care of the harmonics. No need to change unless you hear it though as it seemed to be somewhat random.
Similar to msfistofeles, I didn't really like the stock saddle either. That's a personal preference that you'll need to make though.
I'd ditch the big ring, get a nice cheap BBG bash, and ride the heck out of it! Everything on that bike is good to go. Maybe change bars/seat to suit you best. I think the stock bars are 670, a little narrow for me. And WTB saddles seem to fit me well but YMMV. I think the Silverado is probably the best light vs. comfort deal.
Otherwise a nice light n' blingy tubeless wheelset if you have some spare cash or find a deal.
After that, whatever breaks.
Ditto on the Bash guard. That and quality pedals. Stockers suck more than anything.
My initial thoughts after riding the bike for 3 weeks. The saddle is uncomfortable after an hour in, the bar is a lil narrow (I can deal with it for now), when in small ring & smallest cog the front derailleur rubs like crazy (is that adjustable? Or I shouldn't even be in that gear). This coming week will be the BBG guard 2x10 install, then a hydraulic seatpost (either specialized elite or reverb). I need recommendation for a comfortable saddle, WTB Silverado? I'm having alot of fun with this bike versus my 29er : )
________
Giant Talon 1 29er
Giant Anthem X 29er
Giant Trance X2
Specialized Epic S-Works
Well, yeah, about the cross-chaining thing. One more note about that:
My first full suspension bike had a 20-tooth small chainring. I noticed I was going through chains like crazy until I finally realized how using the small chainring a lot wears out chains much faster since the additional leverage between your pedals and gear dramatically increases chain tension. Since then, I try to use the small chainring as little as possible and it makes a big difference!
