Results 1 to 2 of 2
    Reputation: DerrickT's Avatar
    2011 Trance X shock (RP32 BV) on 2009 Trance X frame?
    The 2011 frame has the same shock length and stroke but compression is fast/high and rebound is medium while the 2008-2010 frames have medium compression and low rebound.
    Since both frames share the same travel and stroke length (1.75"), I'd figure the compression/rebound tune would be relatively the same regardless of "label" on the shock. I have access and really like to try the RP23 Boost Valve (default on 2011 Trance X) on my 2008 Trance X. Would this work? Has anyone tried it? All the hardware looks the same.
    Reputation: mtnbikerfred's Avatar
    You'll probably like that tune better. The early ones had people running a lot higher pressure then they really needed to because they felt"too soft"
    Giant Trance Advanced SL0
    Black Cat 26 " SS
