Results 1 to 7 of 7
    Reputation: parkp81's Avatar
    2011 Giant Trance X1 - Pivot Bearings part number?
    Hello,
    Does anyone that has happened to change their rear triangle suspension pivot bearings know the part numbers for the bearings I will need? I found 3 that are very notchy when I spin them with my finger, I might as well replace all of them.
    May contain nuts
    Reputation: Haggis's Avatar
    I just took apart the rear and found the part numbers:
    6802 - 4x
    6900 - 4x
    6902 - 2x
    I picked up some locally, but I ruined 3 of them installing them, there goes like $17 . They did not go in perfectly straight and when I straightened it out and seated them, they became notchy, probably ruined the "race". So I removed them. I found them so much cheaper on eBay so I'm going to buy them there. Luckily I didn't ruin my frame installing them, and just the bearing, scared the crap out of me.
    May contain nuts
    Notchiness is normal with a small press-fit bearing. Install some full complement bearings, grease them up (mainly to leave no room for moisture) and leave them alone. Knocking them out or wonky pressing is a good way to flog out the housings...
    What are "full complement bearings"?
    I already ordered 3 replacement bearings. The 2RS versions, are the ones I ordered.
    May contain nuts
    Reputation: pharcyde's Avatar
    Just to clarify, for reference and after doing an extensive amount of research on this these numbers will also fit a 2013 TranceX 29:
    6802 - Lower Link front (bottom shock pivot) needs 4 in total. 2 in link and 2 flush fit in frame.
    6900 - Seat stay pivot x 2 and central rocker pivot x 2
    6902 - Chain stay pivot x 2
    Superstar Components UK seem to have the best kit for removal and replacement.
    Any bearing supplier can supply these numbers as they are a standard sizing number.
    KARMA will get YOU & YOU know who you are.
  1. Part number for Giant Anthem rear shock needed
    By fskywalker in forum All Mountain
    Last Post: 07-24-2017, 12:19 PM
  2. My 2011 Giant Trance X Advanced. (Xpost from Giant page.)
    By Uncle Cliffy in forum All Mountain
    Last Post: 01-31-2013, 06:42 PM
  3. llink bearings for my 2009 Giant Trance X frame.
    By Biohazard74 in forum Shocks and Suspension
    Last Post: 08-20-2011, 05:43 AM
  4. 2011 Giant Anthem x2, Giant Trance x2 or Scott Spark 50?
    By dk13 in forum General Discussion
    Last Post: 06-06-2011, 03:13 PM
  5. 2011 m4 pivot bearings siezed
    By Markhester39 in forum Pivot Cycles
    Last Post: 04-25-2011, 08:34 AM
