Results 1 to 5 of 5
    Are the 2011 and 2012 Giant Trance x frames Identical ?
    I was wondering if the 2011 and 2012 Giant Trance x frames are identical ?
    2012 has overdrive 2 but is that just a headset difference ? Could I put the same headset into a 2011 frame ?
    (This stuff is rather new to me, so I may have said something stupid)
    KC Weekend Warrior
    Reputation: the.rebot's Avatar
    Jun 2010
    Headtubes are different, but you can use the 2012 headset in the 2011 frame. Overdrive headtube on 2011, Overdrive 2 headtube on 2012. The bottom diameter of the headtube is larger on OD2... but it seems backward compatible - from DIRTRAG:
    "The steerer tube on OverDrive 2 tapers from 1 1/2" on the bottom to 1 1/4" on top. Giant says that increasing from 1 1/8" to 1 1/4" on the top resulted in a 30% stiffness increase at the handlebars, with no weight penalty thanks to decreased wall thickness of the new steerer. The 1 1/4" steerer tube and associated bearings fit into headtubes on older Giant models designed with 1 1/8" tapered steerers, so upgrading to the new standard is a option for Giant owners."
    http://www.dirtragmag.com/webrag/int...adset-standard
    from PINK BIKE: Giant's OverDrive 2 Steerer tube sizing - Is It The Future? - Pinkbike
    BTW: a great question.
    '12 Giant Trance X1, Mavic Crossride Wheels, StansTubeless, SPD Pedals
    I think the X3 and x4 are the same as 2011.
    Ok cheers guys, I think I have a better understanding now.
    The frames are identical. In fact, Giant introduced the OD2 thing in 2011, in fact. The frame is designed around the cane creek zero stack 44 upper/ zero stack 56 lower standard. The only thing Giant did to incorporate the 1 1/4 upper portion of the steerer tube is use a upper head set cup with a different inner diameter.
