Results 1 to 3 of 3
    2008 Reign zero seat clamp diameter
    Got this frame today, can it be correct that it uses a 35.2 mm seat clamp? It's what I measured, but it sounds like such a irregular diameter.
    Quote Originally Posted by Blather
    keep in mind the seat clamp diameter is not the same thing as the seat post diameter (30.9mm), it has to match the outside diameter of the seat tube.
    Thanks for the heads up, but that I know. Im unsure which size seat clamp I should buy. I have ordered a 30.9 mm seatpost which should arrive shortly.
