    2006 Trance Help
    As the title says, I've got a 2006 Trance that I've had the shock PUSHed, replaced the bearings with Enduro's, and still have vertical play in the rear. It's definitely in the frame, not the wheel. I'm having trouble seeing exactly where it's source is. Ideas????
    Reputation: d365's Avatar
    the linkage?
    Dec 2005
    It could be the DU bushing on the rear shock. Push replaces the bushings when they do the rebuild though, so if it's a recent rebuild it's something else.
    Support your local advocacy group: FVMBA!
    PUSHed as of 1 month ago. I'm thinking it may be the reducers on the shock mount. Anyone have the exact mm sizing on those?
