    Salt Lake City, UT
    '13 Reign 1 / Fork's initial travel is harsh
    (I don't read these forums much so maybe this is a common issue)
    2013 Giant Reign 1 with the Fox CTD Talas Evo fork.
    All is good except the initial travel of the fork; it's way too harsh. It does not seem to absorb those small bumps, chatter and rocks.
    I've messed with air pressure but I really think its a valving issue. If I run lower pressure in an attempt to compensate, it is still stiff, but blows through the mid-stroke, and according to my o-ring, I'm using all but 1cm of the travel.
    Flying downhill in rough rocks & chatter sucks through - I may as well be on a shorter-travel bike.
    I've read that the Talas function is much of the cause of this - true?
    Solution? Revalve from someone like Push I guess?
    May contain nuts
    Reputation: Haggis's Avatar
    All Fox need regular service, oil in lowers may be low or non-existent from new.... worth checking if you haven't all ready. Also make sure the air spring chamber has correct amount of oil - there was a problem where oil was migrating from the lowers into the air spring chamber with 2011-12 Float due to seal design (fixed by replacing foam ring with new seal).
    Salt Lake City, UT
    They've been this way from day 1 - my fault for not checking too far into this when it was new...partially because I was waiting to make sure they were broke in.
    I'll talk to my dealer and see what they think - they are warrantying my drop-post so I need to go in there soon to talk to them anyway.
    Salt Lake City, UT
    I want to revisit this - I have yet to do anything about the issue, but I just emailed Fox and Push to see what can be done.
    I talked to my dealer; they said that the Talas could be removed with a Float damper "which could potentially ease up a source of friction", but I want a firm solution and not a "probably".
    A TON of bikes came with CTD this year, but doesn't anyone else think they completely lack suitable damping in the initial stroke? I hit a small, abrupt channel in the trail tonight and felt a huge shock through the bars - it just can't absorb sudden hits. Pretty annoying.
    Anyone else have this issue and what have you done to fix it? (we'll see what Fox and Push has to say).
  1. '13 Fox CTD Fork on Reign 1 / Too harsh on initial travel
    By KGAmoto in forum Shocks and Suspension
    Last Post: 11-04-2013, 11:36 AM
  2. Replies: 23
    Last Post: 05-10-2013, 02:52 PM
  3. Reign X Riding Harsh
    By sofarider1 in forum Shocks and Suspension
    Last Post: 08-23-2012, 12:29 PM
  4. Reign X riding harsh
    By sofarider1 in forum Giant
    Last Post: 08-22-2012, 08:06 PM
  5. Not so harsh fork for the Monkey?
    By CycleAddict in forum Surly
    Last Post: 08-22-2012, 01:19 PM
