Results 1 to 3 of 3
    Dec 2011
    '12 Anthem rear tri torque specs / bearings?
    Looking for info on how to service the rear end of my bike. Been getting some creaking from there recently and it's gotten to the point where simply touching the rear tire, or shaking the bike laterally holding onto the seat causes a squeak.
    Manually went over the rear arm bolts and one was loose enough to snug up with a hex key.
    Just curious, if I wanted to replace all the bushings, what I'm looking for and appropriate torque specs.
    TIA
    If I recall correctly, 115 inch lbs on the suspension bolts. You might want to check with a dealer to be sure, though.
    Epic rider
    Reputation: rapsac's Avatar
    Sep 2004
    Should still be the same.
    Verstuurd van mijn GT-I9100 met Tapatalk
    Attached Thumbnails Attached Thumbnails '12 Anthem rear tri torque specs / bearings?-uploadfromtaptalk1348350390743.jpg
    12 Anthem X29
    13 XTC 29
    07 Epic Marathon carbon
    04 Stumpjumper FSR Anniversary
    03 Stumpjumper FSR Pro
    00 Rockhopper Pro
