Results 1 to 5 of 5
    2 minutes turkish
    Reputation: locustfist's Avatar
    '08 Reign Chain Guide
    Anyone slap one on yet?
    looking to run two rings and a guard.
    which setup is working best?
    2 minutes turkish
    not even a titter?
    ...tough thread
    Reputation: Sim2u's Avatar
    Nov 2006
    Have you used the search function...there are many threads about this. But to answer quickly:] Im at work and have little time...
    Yep I have put one on.
    Yes it can be done.
    If you choose the E-13 DRS version you will need modification. (coming from the Reign1 06 POV)
    If you choose the Stinger version - which is better in my opinion for this bike; there are 2 varieties to choose from which can be used.
    The stinger requires NO modification and is FAR less in terms of cost.
    At the end of the day you will need a DRS version, BB mount to slap on there.
    Have fun bro...
    attending to my vices
    Reputation: moshelove's Avatar
    Jun 2005
    I use the trvativ dual ring guide. It is about 1/2 pound, goes on easily and works smoothly. it is not to expensive either. I have on 07 reign, but with this type of guide it does not require guide tabs so you should be just fine.
    OVER THE LINE SMOKEY!
    Nov 2006
    I did'nt know Truvativ did a DRS version CGuide, knew they did a SRGuide version though. Oh well, there you go, another option.
