Results 1 to 3 of 3
    Reputation: Dave99's Avatar
    '06 Reign 2 shock orientation question
    '06 Reign 2 comes with a Fox RP3 shock. It's a pain in the a$$ to connect a pump to the schraeder valve because interference with the upper shock linkage.
    I rotated the shock 180 degrees so the schraeder valve is accessible but the now the pro-pedal selector is facing backward. When the shock bottoms out it looks like the pro-pedal selector could hit the frame. It looked real tight when I disconnected the shock and moved the rear wheel to MAX travel.
    Is there a real concern for damaging your shock when rotated 180 degrees during bottom-out?
    Reputation: GiantCHaDSTeR's Avatar
    there's only one way to find. since you rotated the shock already just deflate the shock and compress it! see if there's any clearance issues,
    OK - I went out and reduced shock pressure. I wasn't sure if this was a bad idea as I seem to recall this was a no-no for other rear shocks like the 5th Air and DHX 5.0 Coil.
    Anyway, there seems to be a good 1/4" of clearance between the pro-pedal lever and the Reign frame before the shock compresses the bottom-out bumper. I'm not sure how much further the shock will travel but I suspect it should be OK. This seems like a pretty low risk to me.
    I'll post back if I break my shock.
