Results 1 to 6 of 6
Thread: 05 Reign Help
    Reputation: GiantCHaDSTeR's Avatar
    05 Reign Help
    I need to replace my headset and I need to know what will work or what will you recommend for the 05 Reign?
    Just roll it......
    Reputation: ebxtreme's Avatar
    Quote Originally Posted by GiantCHaDSTeR
    Cane Creek and FSA make some decent zero stacks that'll fit right in there.
    Some info. here.
    Reign X headset
    Reputation: Sim2u's Avatar
    Nov 2006
    Chris King is doing a pretty sick integrated stack now called the "Perdido headset" but it is only offered to frame builders/ manufacturers. No help there hey...? You may wish to enquire further about it. and you may need to ream your headtube though...ha ha ha!
    As said before though, FSA and Cane Creek do the most commonly used varieties.
    Here is a link to it...LINK VERY very sweet indeed.
    Quote Originally Posted by ebxtreme
    Some info. here.
    Reign X headset
    FAST EDDY MUST DIE!!!!!!!
    Which front der is needed for this bike? I know its 34.9 but there are two different versions of the XT. the 770 and the 772. which works for this frame?
    Home of the Tunderbringers! Bringin' that thunder.
    i think the 770 is a low clamp and the 772 is a high clamp. i'm using a low clamp on my 05 Reign
    Just roll it......
    Quote Originally Posted by migzoner
    You want whichever version is a Top Pull / Top Swing.
    EB
