Results 1 to 51 of 51
    Deviant
    Reputation: Weaponized's Avatar
    Oct 2017
    Yup. I'm going to die.
    Whoever said that you never forget how to ride a bicycle was an idiot. These things are going to kill me.
    Sent from my HTC6535LVW using Tapatalk
    Reputation: LargeMan's Avatar
    May 2017
    Lol, make sure you have cleats positioned for early release. Had them opposite once and fell 20 times in one ride before I figured out.
    Deviant
    Oct 2017
    Quote Originally Posted by LargeMan View Post
    The pedals came preset at the easiest release position. The cleat positions is listed in different degrees and I just guessed at that. They seem quite easy to release. It's the remembering to release them part which is difficult.
    May 2017
    Yea, if you switch the cleats around I still, after 20 years, have yet to figure our how to get them to release. They will loosen up after a few rides.
    Self Appointed Judge&Jury
    Oct 2000
    This ^. Time makes it do you can flip the cleats backwards for an easier release. Plus you have the high end XS model. Same as mine. Thereís a tiny screw you can adjust the float with.
    Deviant
    Oct 2017
    Yeah they actually feel about perfect just the way they are in the context of how easy they release. I guess I'll probably want to tighten it up a bit as I get used to it
    Oct 2000
    Are those the Titan XS - carbon / titanium model?
    Deviant
    Oct 2017
    Yes
    Oct 2000
    Quote Originally Posted by Weaponized View Post
    Yes
    Sweet! I started out with the aluminum ones. I ran them to death for 8 years. They never wore out. I upgraded to the XS Carbon Titanium ones like yours and have been running them for 9 years without an issue. Amazing pedals and once your brain clicks with clipping and unclipping youíll never go back to whatever else youíve had.
    Deviant
    Oct 2017
    I can already notice a distinct difference in the amount of power/control I have available to the pedals. I'm going to spend a day in my yard wearing body armor getting used to these things then I'll run a few easy trails before hitting anything too technical
    Formerly of Kent
    Reputation: Le Duke's Avatar
    I rode the Hymasa-Ahab loop in 44:00 this weekend, clipped in, and lived to tell the tale. You'll be fine.
    Death from Below.
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    I've been clipless for a long time. I still fall over sometimes. Ride the neighborhood and stop and click out a hundred times. Before you know it you will wonder how you rode without them. And then you'll fall over again when you stop! Nice pedals.
    My name is Chris and I ride a Prophet 650b with a Lefty.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    I hope your wife is ready to sleep next to a bike
    Deviant
    Oct 2017
    Quote Originally Posted by Procter View Post
    To get it in the house I use the excuse..."I need my suspension at 72 degrees to adjust sag".
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    That's a funny image. A mental learning tool is to think "down and out," meaning push down with your foot then heel out, otherwise you'll try to simply lift your foot up and off the pedal (in which case you'll at least get to test your body armor).
    Deviant
    Oct 2017
    Quote Originally Posted by Nat View Post
    Good tip
    > /dev/null 2&>1
    Feb 2012
    Nice, will have to use that one. What do you say at the dinner table?
    Moderator Moderator
    Reputation: AshevilleMTB's Avatar
    Oct 2014
    At least you'll do so doing what you love
    Deviant
    Oct 2017
    She can't cook so I'm safe there LOL
    Pedal around the neighborhood. One foot clipped in at a time. Practice.
    Deviant
    Oct 2017
    Quote Originally Posted by leeboh View Post
    My yard actually works better. Going fast is easy. It's going really slow when I'm off balance that seems the hardest.
    Reputation: Gasp4Air's Avatar
    20 years ago Times were my first clipless pedals. After numerous "going down like a tree in the woods" falls, I decided it was me or the pedals. I took a file to the cleats and rounded off the sharper features, testing the release as I went. I got them to where I could yank my foot out at will. By the time I wore them out, I found that I'd gotten good enough at it to not need any filing on the new cleats.
    Use it, use it, use it while you still have it.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    was nice knowing you. hopefully you don't explode too...
    Oct 2000
    Quote Originally Posted by Gasp4Air View Post
    Iíve been on them for 17 years. Early on I think it was Jenson that sold ďpre-shavedĒ cleats. I bought a couple sets but soon didnít need them. A buddy of mine back then did what you did after copying Jensons technique. Now they are designed to be switched front to back for an easier release while learning. Once youíve mastered the technique of unclipping in an emergency as you said, just run them in the normal position without fail. Time pedals in my opinion are the best designed pedals out there. No moving parts makes them bomb proof and mud shedding. The easy way you clip in and out is hard to beat. The top of the line Titan XS Titanium / Carbon model is pricey, close to $400. When I bit the bullet and dropped that coin I cringed thinking theyíd be a 3 year pedal. Iíve been beating the crap out of them for 9 years now, zero problems or maintenance. Iím due for a bearing rebuild only because of how long theyíve been going. I havenít noticed any performance loss showing itís time for it. For those not willing to drop that cash they make an all aluminum one for a fraction of the cost.
    For proof of how tough these XS Tiatanium / Carbon pedals are. Go to :05 of this video. I normally rode rocky trails and rarely ever pedal strike. This day about a year ago I was on a groomed single track and managed to smack one of the few boulders at speed. I hit it so hard my rear tire launched sideways into the air and threw me off the trail. The pedal took the full impact and it didnít even damage it. If it were my foot Iíd surly would have broken it. Tough ass pedals for sure.
    :05 here https://m.pinkbike.com/video/471777/
    Moderator Moderator
    I tried swapping to those bitd and found they were very brittle and easily turned into scary jagged objects from pretty common rock strikes. Ended up breaking 3 in less than a season and went back to SPDs, which I tend to get a few years out of at least. If you ride somewhere rocky and want to go with Times, I'd stay away from the Al models myself.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    Deviant
    Oct 2017
    I was able to shop around and get them for $298 on Amazon Prime
    Oct 2000
    Nice! I edited that post above with a video for proof of the bombproof nature of this design. Should give you peace of mind with your purchase.
    Oct 2000
    Quote Originally Posted by slapheadmofo View Post
    Not my experience at all. I edited a video in that post for a proof positive of the bombproof design of those pedals.
    Moderator Moderator
    Didn't you say you were running the carbon version? Whole different animal I'd imagine.
    The Al versions are the only pedals I've ever had that I consistently broke in short order.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Oct 2000
    I rode the aluminum ones for years without issue. The Titan XS Carbon / Titanium ones Iíve been running forever as well. Which is the ones I was running in that video major pedal strike at speed. Didnít even hurt them. I weigh 230 pounds and I was moving at a very good clip. That strike threw my bike sideways and in the air I hit it so hard. Love these pedals and Iím buying another set when it comes time.
    Moderator Moderator
    Glad you had better luck than I did.
    I killed them within weeks, weighing in around 165 and riding mainly slow-ish techy stuff. Think I still have them in the junk pile somewhere; I'll post a pic if I remember.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Oct 2000
    I normally ride fast techy with a mix of slow techy stuff. Granted I rarely pedal strike being on an old geometry bike. That pedal strike was the hardest at speed Iíve ever done in 17 years of riding. It just happened to be on film and with the Carbon pedals that I thought wouldnít be as tough. I canít imagine if my foot hit that boulder instead of the pedal. Ouch! To say the least.
    C8N
    C8N is offline
    Oct 2017
    I was suggested this when I started clipless
    Off topic, but man do I yearn for trails like that. In central CT, it's up a rocky rooty hill and down a rocky rooty hill, repeat. Getting too old (and lazy) for it!
    Reputation: jcd46's Avatar
    That is a sweet trail, I don't think we have that much flow here in SoCal either. ^^
    2016 SC Heckler R build
    2014 All City Macho Man Disc
    Nashbar 29er (Rigid)
    Gravity G29er (SS)
    Giggity
    Deviant
    Oct 2017
    Survived my 1st off-road trip. A short 2 mile loop with this fast section at the start. Really no issues but I never stall on this trail as its mostly beginner-to-intermediate level.
    https://youtu.be/myvoP3Hjlr8
    Oct 2000
    Quote Originally Posted by jcd46 View Post
    Definitely a fun flow trail. I usually ride more techy trails but it was a family reunion and that was a nice break for all skill levels. Iíll have to go hit it again soon. Itís only 1/2 an hour from me. Many other trails connected to it. Hereís another section of that trail from the same day, if interested.
    https://m.pinkbike.com/video/471785/
    Nice, I would ride that every chance I got : ) Nothing like that near me though.
    Gravity G29er (SS)
    Giggity
    Aug 2013
    New to spd?
    Stand over your bike. Jump on and click in as fast as you can. Then, without falling over, quickly detach and try to land on your feet. Do this over and over for a half hour or more, then go for a ride. Your brain should have figured it out and you will instinctually unclip when you lose control/fall.
    Goodbye '95 ZJ. Just so you know, transfering box of left behind womens panties to next truck. Thank you ZJ!
    Deviant
    Oct 2017
    Quote Originally Posted by pdxmark View Post
    New to spd?
    Been doing a similar drill several times a day in my yard. Tomorrow I'm going head-first and trying an intermediate Trail
    Moderator Moderator
    As far as clipping in, start pedaling first and let the cleat find it's way. Sometimes it takes a couple revolutions; no biggie, it's way more important to unclip quickly than it is to clip.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Oct 2000
    Yep, I usually clip one in standing still and then pedal away and let the other one find itís way and clip in. Like you said a revolution or two depending on the terrain.
    Deviant
    Oct 2017
    Well today was trial by fire. I rode the most technical Trail in my area and this thing is a Bruiser even running flats. I went down 4 times and even did an endo once. 2 Falls were the result of a rider stalling mid Trail in front of me, or otherwise I would have made the climbs. The other two were dumbass line choices by myself.
    In any event I felt quite good after this ride and it was a good thing I was wearing good pads. I guess on one hand it could be said it's a little early for me to be riding clipless as a rookie on such trails but that evil little man on my shoulder says... you got this... I'll hold your beer.
    After today I really believe that if you're going to learn clipless, do the scary shit and get it out of the way
    nimble biker
    Reputation: Picard's Avatar
    Apr 2005
    nobody dies. I am disappointed.
    Really? I went back to flats and love it.
    OG Ripley v2
    Carver 420 TI
    Oct 2000
    Quote Originally Posted by TwoTone View Post
    Really?
    Deviant
    Oct 2017
    There will likely be times when I'll swap back to flats for certain things, like casual riding on occasions or places that I don't want to carry extra shoes. Like the beach.
    Reputation: nauc's Avatar
    flats ftw !
    Deviant
    Oct 2017
    Quote Originally Posted by Picard View Post
    The day is Young
    Just practice in the yard. Stop, trackstand and unclip when the bike starts to lean. I never fell when I was learning to ride with them, because I practiced until I got the hang of it. And usually falls at 0 mph don't kill us, just our egos
    Oct 2000
    Quote Originally Posted by nauc View Post
    flats ftw !
    What are you trying to win?
  1. Going to DIE!!!! Bucketlist trip recomendations.
    By haybine in forum Vacations & Destinations
    Last Post: 10-18-2015, 09:01 PM
  2. Stupid Sunday Rant Inaugural ed.: Die butthurt die
    By Slow Danger in forum Off Camber (off topic)
    Last Post: 01-07-2013, 04:52 PM
  3. 11-21-2012: Mr. Toad's Wild Ride! yup, yup, yup
    By parkmeister in forum California - Norcal
    Last Post: 11-21-2012, 11:14 PM
  4. Yup, another brake rubbing thread...
    By mtblucas in forum Brake Time
    Last Post: 05-31-2011, 11:53 AM
Members who have read this thread: 374
